Hi Dylan
Thank you for the info on reset.
I will work on it.
73 David WA9ONY
On Nov 4, 2018, at 7:51 PM, Dylan Ambauen <dylan@ambauen.com> wrote:
Sounds frustrating. Last time I did a hardware reset for the BaseBox5, the instructions seemed kinda vague. And, if you hold the reset button down too short or too long, you'll go into a different hardware mode.  And after reset, I could _only_ reconnect with winbox, IIRC there was no ip interface enabled/configured.
Don't worry, the hardware is probably not ruined, and if it is, it is probably not your fault. Try double-checking hardware reset instructions again, make sure you're doing it right. I think I tried resetting about 10 times before getting it right.
Dylan Ambauen
KI7SBI
On Fri, Nov 2, 2018 at 9:51 AM David Haworth via PSDR <psdr@hamwan.org> wrote:
WinBox V3.18 will not log in to two new BaseBox 5 Intl V6.18.
Login: admin
Password:
WinBox hangs with message
Logging in...
I have reset one of the BaseBox 5 Intl  with no results.
I have tried WinBox V3.18, V3.17, V3.16, V3.15, V3.14 and V3.13.
BaseBox 5 is connected to an antenna.
Using Dell Windows 8.1 laptop with CAT 6A cable connected directly to  BaseBox 5.
No router or hub is being used.
Using MAC or IP Address 192.168.88.1 has no affect.
Board info form WinBox: RB912UAG-5HPnD
IE will not connect to http://192.168.88.1
Both BaseBox 5 make a short funny sound before making the one beep, long delay, two beeps.
The beeps are similar to the QRT 5 power on.
The QRT 5 does not make the short funny sound.
The Dell works fine with a QRT 5 Intl.
http://www.stargazing.net/david/sdr/HamWAN.html#P2a
What do you recommend to try next to get WinBox to work with the two BaseBox 5.
Best Regards
David Haworth, WA9ONY
