I can take care of these updates.  I'll work with Steve.
-Doug-
On Wed, Feb 13, 2019 at 12:00 PM Steve - WA7PTM <psdr-list@aberle.net> wrote:
Is anyone maintaining the
https://www.hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
web page?
The reasons I ask are:
• Step 1 will not work as listed as the command is wrong (should be
"/system package update install" in RouterOS v6.43.12) and if some
preliminary steps are not taken (moving the default network to one
connected to the Internet with a "/ip address add address=a.b.c.d/xx
interface=ether1" command and establishing a default gateway with a "/ip
route add gateway a.b.c.gw" command), then the update will fail.
• Step 21 on a Dynadish5 results in a "failure: incompatible band and
channel-width" message unless "channel-width=5mhz" is added to the command.
• Step 22 on a Dynadish5 results in a "failure: can not run on slave
interface" message.
This last one has me stumped, and I have been unable to determine a
workaround.  Has anyone else encountered and solved this problem?
