The ring is not so much of a ring anymore, it's more of a mesh network topology in reality.  It contains several rings (cycles) inside the mesh (graph).  The HamWAN cell sites offer a standardized network interface (frequencies, bearings, polarizations, bandwidths, modulations, tdma, dhcp, ip).  What you do with that is entirely up to you.  You can connect to any number of sites at once (including multiple sectors at once at each site, and the OPP offering), and have your own private networking in between the routers that interface to HamWAN sites.  You're not limited to using ring topologies in your own networks either.
In short, yes, everything you're talking about is fine and doable.
On 7/15/2018 2:49 PM, Jamie Hughes wrote:
Good afternoon,
Since there is some chatter about support emergency communications stuff, I’d like to ask some questions as well.
Would it make sense to build a small “private” ring that then has a few connection points to a few “cell” sites? IN other words, create a private ring, between all the locations my team needs, and then at a few of those sites, hoping on to the Ham Wan.
The goal would be to use all HAM WAN Routing, but remaining in the local ring unless we needed to route externally.
Jamie Hughes
WA7JH
