I hasten to add, the IP address you want to PING, is (currently) 10.0.0.1.
For lurkers:  Yes, DHCP is enabled on the RF side of the router at the DEM, but if you are having trouble connecting with PINGs, the probability of a successful DHCP IP assignment will be low.
On 2014-05-26 15:15, Dean Gibson AE7Q wrote:
If you want to try to PING the ID-1 at Snohomish County DEM, try the following settings:
In your ID-1:
In your router:
Let me know how it goes ...
On 2014-05-26 11:14, Bob wrote:
It was over four years ago that I started this project.  At the time my knowledge of networking was 2 of a scale of 10.  Today I might be a 3.5; still have a lot to learn.
Initially I had a XP lap top connected directly to the ID-1. It was configured the same as the router below.
I started by pinging the gateway.  LWHC has a number of IP addresses assigned, not all will reply to a pings.
I use “ping 10.0.0.1”  (basic garden variety ping) to determine if I had a usable path.
I then “ping Comcast.net” and got an average reply time of 243ms through the ID-1 and K7LWH-DD.  This compares to a Concast.net ping using my commercial (Comcast) account of 98ms.
I then connected to Bing.com, Google.com and ARRL.org through K7LWH-DD using Internet Explorer.  The performance, subjectively, was a little better than a dial up connection.
I stopped most work on our high speed data project in early 2012.   I reactivated it as a feasibility study rather than an implementation project.
I now have the ID-1 connected to a router.  With a Windows7 computer connected to the router, I can “ping 10.0.0.1” with average times between 110 and 120 ms.  Internet Explore does not connect to Bing, Google, nor ARRL.org  and Packlink indicates that it cannot find a path to a Winlink CMS but somehow messages get to the CMS via telnet connection.
Anyhow, at least for now, we have an alternate path to get emails out of Kirkland if we lose Internet at the City Hall.  I am changing the focus of high speed data transfer away from the ID-1 to HamWAN and  NW-MESH.
Regards
Bob – KE7JL
Sent: Monday, May 26, 2014 9:01 AM
Subject: Re: [HamWAN PSDR] 1.2GHz to Paine [was: 44.x.x.x HamWAN network at Paine]
Ah, I'd like the IP address you are PINGing.  What do you type after the command "ping"?
On 2014-05-25 10:22, Bob wrote:
The router is setup as follows:
          IP: 10.136.19.168
          Sub Mask: 255.0.0.0
          Gateway: 10.0.0.1
          DNS: 10.0.0.2
          Alt: 10.0.0.1
Bob
Sent: Saturday, May 24, 2014 9:33 PM
When you attempt to ping using the K7LWH/DD module, what IP address do you specify?
On 2014-05-24 14:36, Bob wrote:
Here are some observations and conclusion that I have come up with in adding the ID-1 to the Kirkland Emergency Communications Team’s tool box.  I have done a number of tests of the ID-1 from various locations in Kirkland in both the Digital Data (DD) mode and the Digital Voice (DV) mode.  I tested simplex paths (ID-1 to ID-1) and paths to the Lake Washington Ham Club (LWHC) DSTAR DV repeater and DD gateway nodes in Bellevue.
1.      There are a few locations in Kirkland that have direct visual line of site to LWHC Gateway in Belleview.  From those locations, pings are consistently returned in 100 to 200ms with an occasional loss.
2.      We have two location (Stations 22 and 25) are not visual but according to Radio Mobile modeling skim the terrain.  At these sights no ping are returned.
3.      At my home QTH (Lat: 47.694 Lon: -122.2161) I do not have a visual of the LWHC Gateway, but I get occasional pings returned.
4.      John Hays loan me a 1.23 GHz directional antenna. With the directional antenna I detected two paths to the gateway.  One was off a condo about 180 degrees from the gateway about a mile away; the other was off the NOAA building four miles awat at Sand Point about 15 degrees clockwise from the gateway.  This indicates the presents of multi-paths that could be interfering with the data even with good signal strength.
5.      I will also confirm the DV mode is more robust than the DD mode, but it too is affect by multi-path.
Bob – KE7JL
