On Sun, Apr 20, 2014 at 5:51 PM, Dean Gibson AE7Q <hamwan@ae7q.com> wrote:
Actually, what would be helpful (and motivate sharing of dynamic data), is for the text in those "click-on bubbles" for each site to indicate the "type" of data. Eg (these are just ideas; some of them are mutually exclusive):
Site survey 2013-06-07
Static report 2014-02-14
Dynamic report 2014-04-02 16:53Z
Online; status at 2014-04-20 17:37Z
Offline; last online 2014-04-19 02:15Z
I agree the map data could use more verbosity. These are the current types of map data:
- Coverage (the red overlay)
- Site (the radiation symbol)
- Link (PtP between sites)
- Client
- Site survey (non-live client data)
All data are online/live unless labeled "site survey". Online nodes are represented by blue lines where the line width is related to the current negotiated link speed (this fluctuates a bit). When a client drops offline, the link line disappears and the signal strength shows "null dBm"--essentially no special handling in the software, the value just goes away. Signal surveys are gray lines, indicating a tested path but no connection.
The data is collected with SNMP into Cacti, then aggregated into a JSON file for the website. Javascript parses the JSON file and places the data on the map. I've been working on a portal website to allow people like you to edit DNS entries and edge firewall rules for your hosts. Eventually, I'll consolidate the map data into this database so you can update things like lat/lon yourself. Then I'll clean up the JSON a bit, and finally clean up the javascript that generates the map. If you'd like to jumpstart integration of your suggested changes into the map, you can start work on the javascript while I finish up the back end. Just click View Source on hamwan.org and you should have everything you need.
