You can do a bit more debugging
here to bridge the gap between "config upload" and
"connections don't work". The router has a nice "/tool
sniffer quick" utility built-in. Try it with the arguments
"interface=all ip-protocol=tcp port=26" and launch a
connection in from the outside world. You should be able to
see everything going on, from the original packet coming in
(or not), to it getting translated and sent to your server
(or not), to your server replying (or not), to the un-NAT
and retransmission (or not). Somewhere along the line
you'll spot the root of the problem. I don't know what it
is, as the config looks fine to me.
Oh, and screen width DOES matter. I believe if your window
isn't wide enough (eg: just 80 columns) it'll omit MAC
address details. So, max your window before running the
sniffer. Either that or use the winbox GUI sniffer.
Please report back!
On 04/03/2014 05:17 PM, Dean Gibson AE7Q wrote:
Objective: When an external (ie, wlan) connection is
attempted to port 26 on the radio, forward that traffic
("destination NAT") to a computer on my internal LAN.
Firewall rules in the radio (rules #3 & #7 in the filter
chain, and rule #1 in the NAT chain, have been inserted by
me):
/ip firewall filter
print
Flags: X - disabled, I - invalid, D - dynamic
0 ;;; default configuration
chain=input action=accept protocol=icmp
src-address=44.0.0.0/8
1 ;;; default configuration
connection-state=established
2 ;;; default configuration
connection-state=related
3 chain=input action=accept
protocol=tcp in-interface=wlan1-gateway
dst-port=26
4 ;;; default configuration
chain=input action=drop
5 ;;; default configuration
chain=forward action=accept
6 ;;; default configuration
7 chain=forward
action=accept protocol=tcp
in-interface=wlan1-gateway dst-port=26
8 ;;; default configuration
chain=forward action=drop
connection-state=invalid
/ip firewall nat print
chain=srcnat action=masquerade
to-addresses=0.0.0.0 out-interface=wlan1-gateway
1 chain=srcnat
action=masquerade to-addresses=192.168.0.250
protocol=tcp out-interface=ether1-local dst-port=26
2 chain=dstnat action=dst-nat
to-addresses=192.168.0.250 protocol=tcp
I use the same technique on my Linux boxes, and it works
fine (albeit iptables is slightly different). However, when
accessing my radio from an external IP address, no
connection is made (times out). If I change the dstnat rule
action to "accept", the connection is refused. The logs for
port 26 on the target device (192.168.0.250) show no
connection attempt. In the (default) srcnat chain,
"action=masquerade" implies NATting on the return trip (into
the LAN). The same thing needs to happen in a dstnat chain,
but I don't see a way to do that; I'm "assuming" that the
OS automatically does that. When doing DNAT on Linux, I
have to do that manually, with the same rule in the
"PREROUTING" and "OUTPUT" NAT chains, but those chains don't
exist in my radio.
Ideas welcome (note that "action=masquerade" is not valid in
a dstnat chain).
