John,
They are both running.  I did not do anything special other than the client-configuration and manually setting the country to no country via the Wireless tab when the script failed during the item 21 configuration.
Bob Sampson
k6mby@olypen.com
360-477-0776 (cell)
Sequim, WA
Message: 1
Date: Wed, 04 Mar 2020 18:05:20 -0800
To: "Puget Sound Data Ring" <psdr@hamwan.org>
Cc: "psdr" <psdr@hamwan.org>
Subject: Re: [HamWAN PSDR] Configuration failure
Message-ID: <170a870a733.efd11161166045.5362718638499091690@jmit.com>
Content-Type: text/plain; charset="utf-8"
Bob,
One out-of-the-blue question: Do you have both chains enabled on the radio? The factory default setting (for the RB912UAG-5HPnD at least) is to just enable chain 0.  Last time I checked, the configuration instructions on the HamWAN web site don't enable the second chain (chain 1).  Enabling the second chain can make a pretty substantial difference in net signal margin and stability.
Assuming that you are using a MIMO radio, to check this run:
/interface wireless monitor 0 once
You should have these lines in the display:
signal-strength:
signal-strength-ch0:
signal-strength-ch1:
tx-signal-strength:
tx-signal-strength-ch0:
tx-signal-strength-ch1:
If you only have the following, then you are running in single-chain mode:
signal-strength:
tx-signal-strength:
To enable both chains:
John KX7JM
John C. Miller
mailto:john@jmit.com
(530)873-9005
---- On Sat, 29 Feb 2020 05:51:14 -0800 Bob.k6mby <k6mby@olypen.com> wrote ----
Thanks Carl.  Went in the wireless tab and set country and frequency mode then ran the regular item 21 config line and it went without error.
Bob
K6MBY
Sequim,  WA
mailto:PSDR@hamwan.org
-------------- next part --------------
An HTML attachment was scrubbed...
URL: <http://mail.hamwan.net/pipermail/psdr/attachments/20200304/9d582087/attachment-0001.html>
Subject: Digest Footer
End of PSDR Digest, Vol 85, Issue 2
