Global reachability is not in conflict with autonomy. Achieving both simultaneously just requires careful design of HamWAN network services. If the HamWAN internet feed drops off, the routing, DNS and other services need to continue working. The first word in ASN is Autonomous after all. :)
I consider NAT and Proxies as old crusty hacks from the age of ISPs giving out just 1 IP/customer. It's time to put these ideas to rest. IPv6 will do this on the commercial internet in the coming years, and AMPRnet will allow us to do it immediately here. For the cases where communication is to be restricted due to user preference, we can push filtering rules to firewalls at the edges of the network, and at the HamWAN <-> user site interface. In short, firewalls: yes, nat+gateways: no.
If a user wants to make a service running on one of his servers public, he just needs to push an ACL update to HamWAN and it'll be opened up. No need to re-IP, update DNS, change NICs, whatever else. And most importantly, it makes everyone equal. Your subnet allocation has the same powers as mine. There is no special ground to fight over, such as space on a public subnet, or access to some officially sanctioned gateway servers that are allowed to do special things.
If you want though, you can of course live in the world of private IPs and NAT. Just configure your LAN router that way.
Complete freedom of configuration. This is the way the internet should have evolved for geeks!
On 2/13/2013 8:30 AM, Cory (NQ1E) wrote:
Unless I've misunderstood the point of this network all together, there shouldn't be a case where we want the entire network address space to be reachable from the global internet. It's much more likely that the network will remain as autonomous as possible and any connections to the internet will be for connecting specific services through a gateway of some sort.
A subnet of at least /23 (typical minimum for global BGP announcements) should be reserved for the purpose of being globally routable in the future, if/when HamWAN decides to peer with one or more ISPs. An address in the /23 can be given to each service gateway for connecting to the internet.
The rest of the 44-net allocation can be treated as private address space, except that it's essentially guaranteed not to cause conflicts with the user-level networks since it's still globally unique.
On Wed, Feb 13, 2013 at 2:28 AM, Bart Kus <me@bartk.us> wrote:
Clever ;)
What if HamWAN switches ISPs? All that IPv6 space would need to be given up. It can't follow you AFAIK. Or the ISP may charge whatever they feel like to let you take it with you. Also bad.
The fees for IPv6 are not as low as I had hoped, but not as high as you think either! There's a 25% discount in effect for "extra-small" allocations (which are still larger than the entire IPv4 internet). The cost looks to be $937.50/yr. Not sure it's worth the cost, given the IPv4 AMPRnet situation. We can very likely just expand our AMPRnet allocation if we out-grow the /20.
On 2/13/2013 1:10 AM, Cory (NQ1E) wrote:
Here's an IPv6 allocation for you ;)
::ffff:44.24.240.0/116
With the obvious exception of AMPRNet addresses for amateur radio use, IP allocations should come from an ISP. Obtaining a direct allocation from ARIN would cost around a couple grand per year.
On Wed, Feb 13, 2013 at 12:46 AM, Bart Kus <me@bartk.us> wrote:
Result: APPROVED
Your allocated subnet is: 44.24.240.0 / 20
https://portal.ampr.org/networks.php?a=region&id=191
HamWAN now has 4096 real Internet IPs to play with. Next up: we gotta crack the mystery of getting IPv6 net space. Any volunteers? :)
What an incredibly productive day,
