I can't seem to login to your modem (prompted for password) to troubleshoot any further.  All I can do is confirm tom's findings that the link speed seems OK:
[eo@Baldi-S3] > /tool bandwidth-test 44.24.240.251 duration=20s direction=receive
                status: done testing
              duration: 20s
            rx-current: 14.2Mbps
  rx-10-second-average: 14.3Mbps
      rx-total-average: 14.0Mbps
          lost-packets: 1280
           random-data: no
             direction: receive
               rx-size: 1500
[eo@Baldi-S3] > /tool bandwidth-test 44.24.240.251 duration=20s direction=transmit
              duration: 20s
            tx-current: 13.1Mbps
  tx-10-second-average: 12.8Mbps
      tx-total-average: 12.2Mbps
           random-data: no
             direction: transmit
               tx-size: 1500
If you'd like more diagnostics, please make sure steps 5 & 6 are executed on your device:
http://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
On 11/3/2019 8:57 AM, Scott Currie wrote:
I am still seeing slow TX speeds when I run the test from the client end. Am I doing something wrong? Wrong IP?
/tool bandwidth-test 44.24.240.197 duration=30s direction=transmit
                status: running
              duration: 29s
            tx-current: 11.9kbps
  tx-10-second-average: 11.9kbps
      tx-total-average: 41.1kbps
           random-data: no
             direction: transmit
               tx-size: 1500
      connection-count: 20
        local-cpu-load: 4%
[ns7c@WA7AUB-Baldi] > /tool bandwidth-test 44.24.240.197 duration=30s direction=receive
                status: running
              duration: 29s
            rx-current: 13.1Mbps
  rx-10-second-average: 14.4Mbps
      rx-total-average: 13.4Mbps
          lost-packets: 1439
           random-data: no
             direction: receive
               rx-size: 1500
        local-cpu-load: 12%
On Sat, Nov 2, 2019 at 9:41 AM Tom Hayward <tom@tomh.us> wrote:
His speeds look fine today.
[tom@Baldi-S3] > /ip dhcp-server lease print
Flags: X - disabled, R - radius, D - dynamic, B - blocked
 #   ADDRESS                                                            MAC-ADDRESS       HOST-NAME                           SERVER                           RATE-LIMIT                           STATUS
 0 D 44.24.240.252                                                      64:D1:54:AD:8C:13 W7CLO-Baldi                         dhcp1        bound
 1 D 44.24.240.251                                                      CC:2D:E0:1E:DE:C7 WA7AUB-Baldi                        dhcp1        bound
[tom@Baldi-S3] > /in wi registration-table print
 # INTERFACE        RADIO-NAME       MAC-ADDRESS       AP  SIGNAL-STRENGTH TX-RATE UPTIME
 0 wlan1-gateway        W7CLO/Enumcla... 64:D1:54:AD:8C:13 no  -70dBm          29.2... 13h34m40s
 1 wlan1-gateway        WA7AUB/Auburn... CC:2D:E0:1E:DE:C7 no  -73dBm          29.2... 13h34m40s
[tom@Baldi-S3] > /tool bandwidth-test  44.24.240.251 duration=10
              duration: 10s
            rx-current: 14.8Mbps
  rx-10-second-average: 14.0Mbps
          lost-packets: 0
           random-data: no
             direction: receive
               rx-size: 1500
[tom@Baldi-S3] > /tool bandwidth-test  44.24.240.251 duration=10 direction=transmit
              duration: 11s
            tx-current: 14.2Mbps
      tx-total-average: 12.8Mbps
           random-data: no
             direction: transmit
               tx-size: 1500
On Sat, Nov 2, 2019 at 8:31 AM Bart Kus <me@bartk.us> wrote:
If it's a pre-wired unit like the DynaDish 5, you can't change polarities.  Will just need to live with the confusion.
That is pretty bad upload performance.  It could use some spectral analysis on the HamWAN side, and perhaps testing with another client on the same sector to find the cause.  I hope it wasn't caused by the 10MHz bandwidth change!
I don't have time to address this right now, so hopefully someone else can step in.
The download numbers look fine though.
On 11/1/2019 8:22 PM, Scott Currie wrote:
So, it's not clear to me how to change the polarity on the channels. I'll do some reading. It's a DynaDish 5.
These numbers look low, I may not be doing this right:
                status: running
              duration: 29s
      tx-total-average: 25.7kbps
           random-data: no
             direction: transmit
               tx-size: 1500
        local-cpu-load: 4%
                status: running
              duration: 29s
            rx-current: 12.8Mbps
  rx-10-second-average: 12.2Mbps
      rx-total-average: 12.0Mbps
          lost-packets: 1192
           random-data: no
             direction: receive
               rx-size: 1500
        local-cpu-load: 16%
-Scott
On Fri, Nov 1, 2019 at 8:06 PM Bart Kus <me@bartk.us> wrote:
It appears you're connected to the Baldi site.  That's probably the only site remaining that still doesn't have MIMO (2-chainz) modems.  It only provides service with horizontally polarized signals.
It looks like your modem's setup to receive HPol on ch1.  HamWAN typically suggests HPol be wired to ch0, and all our network gear follows that standard:
http://hamwan.org/Standards/Component%20Engineering/Client%20Hardware.html
It makes troubleshooting easier when there's a clear polarity-to-chain mapping.
I'm also not sure why we're still running that sector at 5MHz bandwidth, it should be 10MHz.  I've gone ahead and updated the sector's config to be 10MHz.  This should provide you with a bit more speed, at the cost of 3dB of signal power, which you can afford given your -66dBm link.
Feel free to run some bandwidth-tests to Baldi-S3.hamwan.net (44.24.240.197) to confirm performance.
PS: The "tx-signal-strength-ch0" is reported back to you from Baldi-S3 (how well it hears you), since Baldi-S3 only has a ch0, even though that's not your tx-ch0, but rather your tx-ch1 that it's measuring.  You see how confusing things get when polarities are flipped?  :)
On 11/1/2019 7:46 PM, Scott Currie wrote:
So, should I be concerned about my ch0 numbers?
-Scott
[ns7c@WA7AUB-Baldi] > /interface wireless monitor 0
                  status: connected-to-ess
                 channel: 5880/5/an
       wireless-protocol: nv2
                 tx-rate: 6.5Mbps-5MHz/1S
                 rx-rate: 13Mbps-5MHz/1S
                   bssid: D4:CA:6D:7A:A3:EF
              radio-name: N7FSP/Baldi-S3
         signal-strength: -66dBm
     signal-strength-ch0: -90dBm
     signal-strength-ch1: -66dBm
      tx-signal-strength: -67dBm
             noise-floor: -101dBm
         signal-to-noise: 35dB
                  tx-ccq: 47%
                  rx-ccq: 79%
   authenticated-clients: 1
        current-distance: 31
                wds-link: no
                  bridge: no
        routeros-version: 6.41.3
Sent from my mobile device...
-Scott
-Scott
