Bart,
I've seen several of these e-mails about the project, but don't remember seeing an explanation of a key aspect.
What is the plan to connect the buildings with gigabit Ethernet?  Are you planning on digging a trench, stringing the CAT5 along the tree's or something else? Sorry, I am not familiar with the layout or location of these different buildings. so maybe that is a good place to start with your plan? Have you received permission from the site owners for this work?
On Sun, May 31, 2020 at 11:08 PM Jason J. Hill <Jason@pnwrr.com> wrote:
I like this idea. It looks like the wiztronics site would be the one you'd like to put the link to rattlesnake on. Since we don't currently occupy their main tower structure, we can check with them to see if a dish could be covered under our current lease at no additional cost if you'd like.
Jason
kd7tqn
------ Original message------
Date: Sun, May 31, 2020 10:48 PM
To: Puget Sound Data Ring;
Cc:
Subject:[HamWAN PSDR] VOTE: Baldi LAN expansion and Rattlesnake link
We have 4 clients connected to Baldi-S1 (a SISO sector) that are kind of silly:
 # INTERFACE  RADIO-NAME       MAC-ADDRESS       AP  SIGNAL... TX-RATE UPTIME
 0 wlan1      AF7PR-Baldi      E4:8D:8C:C6:F5:45 no  -60dBm    32.5... 2d8h51m46s
 1 wlan1      KD7TQN-Baldi     D4:CA:6D:C2:ED:93 no  -65dBm    32.5... 2d8h51m32s
 2 wlan1      N7OEP/Baldi-B... D4:CA:6D:0D:53:F9 no  -60dBm    32.5... 2d8h51m27s
 3 wlan1      Rattlesnake-B... 64:D1:54:AF:3F:CD no  -79dBm    19.5... 1d9h35m21s
They're silly because the first 3 are at the same mountain top, just a couple hundred feet away in adjacent shacks.  This is a waste of prime long-range spectrum, being used to do local-links.  I'd like to get all the shacks @ Baldi tied together via gigabit Ethernet, and install access switches at the 2 other shacks so people there can plug into the LAN directly.  This high speed LAN between all shacks can then be used to allow us to address the 4th silly client, which is Rattlesnake Mountain.  I'd like to install a dedicated dish on the northernmost tower (fed by the new high speed LAN) to act as a dedicated high speed link between Baldi and Rattlesnake.  The dish on the Rattlesnake side will also need a modem upgrade to run at full speed, and I'm including that in this proposal.
Here is the rough budget for this spend request:
Item
Quantity
Cost
Subtotal
500ft pull rope
1
$12.97
$12.97
425ft duct rod
1
$111
$111
Taxes for above 2 items
1
$11.53
$11.53
CRS112-8P-4S-IN for northernmost building, feeding Rattlesnake dish w/ PoE and access ports for clients
1
$170
$170
CRS326-24G-2S+RM for middle building, acting as mid-span switch and providing ports to lots of devices there
1
$185.24
$185.24
1
$33.04
$33.04
1000ft Shielded CAT5 TC-PRO ToughCable
1
$137.68
$137.68
Taxes for above
1
$12.80
$12.80
Existing Inventory Estimate: RB921UAGS-5SHPacD-NM modem
2
$150
$300
Existing Inventory Estimate: mANT30 2ft microwave dish
1
$120
$120
Existing Inventory Estimate: Sleeve30 2ft microwave dish isolation kit
1
$100
$100
TOTAL COST ESTIMATE
$1,194.26
Current HamWAN balance is about $16k.
Procedural reminder since we haven't had one of these emails in way too long: HamWAN directors have 24 hours to vote upon such spend decisions, and members have the same time to weigh in with opinions to influence director votes.  Our procedures are documented here:
http://hamwan.org/Administrative/Constitution.html
