It all depends on the distance involved. If you are talking a few blocks (less than a half a mile), you should get through some limited amount of leaves. I’ve gone 0.6 miles testing with some shrubs in the way, but that’s the limit I’ve found.  I’ve not tried through glass, so can’t speak to that. If it is totally clear, plain, glass, you should get some performance. If there is any kind of tinting, eco-surfaces, etc., forget it.  Wood is worse than leaves, maybe 600 to 1000 feet.  For anything longer, you need true line of sight (you look through binoculars and see the other end of the shot).  There is also the Fresnel zone, a somewhat cigar shaped elliptical, narrow at the ends and wider in the middle. For best results, there should be no obstructions in the Fresnel zone (not just in the basic direct LOS). You can find Fresnel zone calculators on line.
I have found the Dynadish5 to be the best choice for shots up to maybe 10 or 15 miles. Beyond that you will want the mANT30 dish with proper routerboard. However, I am aware of at least two shots where the Dynadish outperformed the mANT30 on shots over 25 miles.  The higher gain really matters on the long shots.  The LHG5 is okay for perhaps 5 miles (with clear LOS).
Sent: Friday, May 28, 2021 9:51 AM
To: psdr <psdr@hamwan.org>
Hey everyone!
Jesse
KJ7YLS
