On Wednesday, November 23, 2022 at 12:00:21 PM PST, psdr-request@hamwan.org <psdr-request@hamwan.org> wrote:
Send PSDR mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
When replying, please edit your Subject line so it is more specific
than "Re: Contents of PSDR digest..."
Today's Topics:
1. RouterOS question (Rob Martin)
2. Re: RouterOS question (Tom Hayward)
3. Re: RouterOS question (Jamie Owens)
4. Re: RouterOS question (Bart Kus)
5. Re: RouterOS question (Stephen Kangas)
Message: 1
Date: Wed, 23 Nov 2022 03:00:30 +0000 (UTC)
Subject: [HamWAN PSDR] RouterOS question
Content-Type: text/plain; charset="utf-8"
I am trying to achieve something using RouterOS scripting, and I'm hoping that here I might find the appropriate expertise.
>From a script running in a Mikrotik router I wish to pull in a copy of a file from an attached Windows computer. The computer is on the same subnet as the router.
By way of illustration:
A file called test.xxx exists on a Windows computer in the folder c:\aaa\
I want a copy of this file to appear in the attached router /file list. This copy "event" could be either a push from the computer, or a pull from the router.
When using Winbox, this function is achieved easily using "drag and drop", but I need to automate the function.
Thanks.
RobK7QJ
-------------- next part --------------
An HTML attachment was scrubbed...
Message: 2
Date: Tue, 22 Nov 2022 21:46:48 -0800
Subject: Re: [HamWAN PSDR] RouterOS question
Message-ID:
Sounds like you just need /tool fetch.
The blacklist script is a thorough example:
> as the router.
> c:\aaa\
> from the router.
> Thanks.
> Rob
> K7QJ
Message: 3
Date: Wed, 23 Nov 2022 00:59:11 -0800
Message-ID:
Yep just use fetch with mpde=ftp and setup ftp server on windows box,
problem solved
On Wed, Nov 23, 2022 at 12:57 AM Tom Hayward <
>> as the router.
>> c:\aaa\
>> from the router.
>> Thanks.
>> Rob
>> K7QJ
>> PSDR mailing list
Jamie Owens
Message: 4
Date: Wed, 23 Nov 2022 10:52:57 -0800
Content-Type: text/plain; charset="utf-8"; Format="flowed"
Alternatively, you can push from Windows, by having an SSH key installed
and using SCP:
> problem solved
> the folder c:\aaa\
> Thanks.
> Rob
> K7QJ
> Thanks,
> Jamie Owens
Message: 5
Date: Wed, 23 Nov 2022 11:17:03 -0800
Message-ID: <31e5201d8ff70$2de768b0$89b63a10$@kangas.com>
Bart’s suggestion is a better way as it is much more secure. Allowing FTP to be run at any time in RouterOS is asking for trouble, as it can be potentially be used for a bad actor to infect your device. SCP (Secure Copy Protocol) is not only encrypted but using Secure Shell (SSH) to access it helps prevent problems.
Sent: Wednesday, November 23, 2022 10:53 AM
Alternatively, you can push from Windows, by having an SSH key installed and using SCP:
Yep just use fetch with mpde=ftp and setup ftp server on windows box, problem solved
Thanks.
K7QJ
Jamie Owens
Subject: Digest Footer
End of PSDR Digest, Vol 117, Issue 1
