Hi Dave,
You can get uptime for your link with the command:
/in wi registration-table print
The uptime should reflect the last time your radio registered with an AP.
John KX7JM
---- On Wed, 13 May 2020 06:37:20 -0700 Bart Kus <me@bartk.us> wrote ----
Yes, you can get more info about the problem if you run continuous
traceroutes (eg: https://en.wikipedia.org/wiki/MTR_(software)). Both
from the inside-out and outside-in would be useful data sets. They'll
show you the transient routing problems.
On 5/13/2020 6:33 AM, David C. Jenner wrote:
> Thanks for the info, Bart.
> I don't see any indication of uptime using
> /interface wireless monitor 0.
> The interface status seems to be nominal.
> Inspection of the logs indicate that the connection has be active for
> many (9?) days.  That includes many (dozens of) downs/ups.
> My indication of down/up comes from outside monitoring by a service
> that pings every few minutes.  That's what is indicating down.
> Also, my router (from the inside) indicates down/up based on latency
> and packet loss.  That does produces alerts, but less frequently.
> I suspect that there may be a "problem" upstream of my dish?  Is there
> some way of determining that?
> 73,
> Dave
> K7DCJ
> On 5/11/20 11:51 AM, Bart Kus wrote:
>> You can query your device log (/log print) to see if you see YOUR RF
>> link dropping.  You can also get the link's current uptime (/int wir
>> mon 0) to see if it's been up for days or just minutes.  If your link
>> is stable, it's likely a HamWAN problem deeper in the network.
>> --Bart
>> On 5/11/2020 10:09 AM, David Jenner via PSDR wrote:
>>> My connection (K7DCJ-Buck) has been down for a few minutes a couple
>>> of dozen times in the last two days.  Is the source of this known,
>>> or is it at my place?
>>> 73,
>>> Dave
>>> K7DCJ
>>> _______________________________________________
>>> PSDR mailing list
>>> PSDR@hamwan.org
>>> http://mail.hamwan.net/mailman/listinfo/psdr
