On 2014-03-21 23:09, Tom Hayward wrote:
On Fri, Mar 21, 2014 at 8:40 PM, Dean Gibson AE7Q <hamwan@ae7q.net> wrote:...Dean, This is a really good question. DNS is an essential service for a network. It makes higher-level services much more useful (who wants to memorize IP addresses? Okay... other than me!). HamWAN plans to let you create *.hamwan.net hostnames. At the moment, the DNS servers are running (redundant, at multiple sites), but there's no user interface for people like you to add entries. Only a few records have been manually entered.
You have a user interface. If you are running ISC's BIND version 9, in your master "named.conf" file, add the following clause to the "zone" statement for "hamwan.net": update-policy { };
Then, once for each user, you just need to do (substitute the user's callsign for ae7q):
- On a Linux system, run: dnssec-keygen -a HMAC-MD5 -b 128 -n HOST ae7q
- Send the user a copy of the "Kae7q.+157.#####.key" file. The user will use the key value in the radio's "/tool dns-update ..." command (or equivalently, the Linux "nsupdate" command) whenever the IP address needs to be updated. You'll need to tell the user the IP address of the master DNS server (probably a.ns.hamwan.net = 44.24.244.2, unless your A and B DNS servers are slaves to a hidden master).
- In your master "named.conf" file, add the following line, using the key value from the above file: key "ae7q" {algorithm hmac-md5; secret "key value..."; };
- In your master "named.conf" file, in the zone statement for "hamwan.net", insert the following into the "update-policy" clause: grant "ae7q" subdomain "ae7q.hamwan.net";
- Reload BIND (named). On CentOS: service named reload
This way, users will only be able to create/update DNS records of the form "anything.<only-their-callsign>.hamwan.net".
ps: I've tested this on my own DNS servers. It's much better than using the zone "allow-update" clause, because the latter applies to a whole zone (which would mean creating a new zone for each user ...).
So, what ARE we doing here? We've chosen to keep the data which
feeds PowerDNS in a PostgreSQL database. This shifts the problem
of updates and replication into the database realm. The presence
of said database also provides us a fairly universal and highly
adaptable place to keep all other configuration and state
information. The problem is now reduced to just allowing users
secure and Part97 compatible access to PostgreSQL. That problem
is solved by PostgreSQL's support for certificate-based
authentication of users. We have not yet verified if the sessions
PostgreSQL provides also provide HMAC support after the identity
is established, while avoiding encryption. If that's possible,
then great, we're done. If not, we can do some further work to
make that happen.
