Hi Jamie,
Wlan1 needs to be removed from the bridge.
Do /interface bridge port print
Then remove the port listed for wlan1
Based on your previous output, it would be:
print
remove 1
Then retry step 22
/ip dhcp-client
add add-default-route=yes dhcp-options=hostname,clientid disabled=no interface=wlan1
KI7SBI
Dylan Ambauen
360-850-1200
On Sat, Feb 27, 2021, 17:11 Jamie Hughes <wa7jh@outlook.com> wrote:
Sorry to pester,
So I am now on step 22 and I get the error listed, however, I am not sure what to do to overcome the error as described in the notes under the step.
Here are the results from running the commands as listed:
[admin@KC7Z-East_Bremerton-Gold_Mt] /ip dhcp-client> /interface bridge port print
Flags: X - disabled, I - inactive, D - dynamic, H - hw-offload
 #     INTERFACE              BRIDGE             HW  PVID PRIORITY  PATH-COST INTERNAL-PATH-COST    HORIZON
 0     ;;; defconf
       ether1                 bridge             yes    1     0x80         10                 10       none
 1 I   ;;; defconf
       wlan1                  bridge                    1     0x80         10                 10       none
Jamie Hughes
WA7JH
Phone: (360) 362-4575
-----Original Message-----
Sent: Saturday, February 27, 2021 16:54
To: Jamie Hughes - WA7JH <wa7jh@outlook.com>
Subject: Re: [HamWAN PSDR] Support needed
See the notes below the command.
I've seen that before, but don't recall how I solved it.  Sorry.
Jamie Hughes wrote on 2/27/21 4:49 PM:
> Well,
> Step 22 presents this error:
> failure: can not run on slave interface
> Jamie Hughes
> WA7JH
