When I first got my HamWAN setup (32" reflector w/ a Microtik
router) in February of some year in the past, I aimed it out a 2nd
story window (double-paned glass) to the HamWAM Paine Field
(actually, Snohomish County DEM) node, 5 miles away. Worked fine,
so I mounted the dish on the roof.
Starting in July, over that month, reception gradually dropped from
good to marginal to non-existent. Reception didn't come back until
the next January. This pattern repeated for the next three years,
at which time I gave up.
We never did find the cause. Seasonal foliage didn't seem to match
the pattern.
Good luck!
On 2021-05-28 09:51, Jesse Victors via
PSDR wrote:
Hey everyone!
HamWAN has been on my radar for a couple months and I wanted to
get connected. I have a couple options.
1) if 5 GHz can pass through double-paned glass, then I could
point an antenna through the window from my work office in
downtown Seattle, connecting with the hubs nearby or across the
water.
2) if 5 GHz can pass through tree leaves, I could mount the dish
on the mast holding the center of my HF fan dipole, as shown here:
https://www.qrz.com/db/kj7yls
At a height of 30 feet it might be able to connect with Paine.
3) if 5 GHz can pass through a thin piece of plywood and tree
leaves, I could mount the antenna in my attic. That should be tall
enough to jump over my neighbors house I think.
Which of these would work? I'm leaning towards the first option.
The second would work but it would just be more logistically
difficult. I believe the third option would suffer significant
signal degradation, yes?
As far as antennas go, the LHG 5 seems to have pretty good
performance, is within my hobby budget, and should work for the
links that I have in mind, yes? It should also be lighter and more
wind-resistant since its hollow. I should be able to mount that on
a pole, connect PoE, and then work on the routing, correct? If
this is a decent choice, where is a good place to order the
International edition?
Jesse
KJ7YLS
