I did:
=>dig -x 44.24.240.173
@a.ns.hamwan.net.
; <<>> DiG 9.2.4 <<>> -x
44.24.240.173 @a.ns.hamwan.net.
; (1 server found)
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status:
NOERROR, id: 55622
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 0,
ADDITIONAL: 0
;; QUESTION SECTION:
;173.240.24.44.in-addr.arpa. IN PTR
;; ANSWER SECTION:
173.240.24.44.in-addr.arpa. 3600
IN PTR ae7q.hamwan.net.
;; Query time: 147 msec
;; SERVER: 44.24.244.2#53(44.24.244.2)
;; WHEN: Thu May 15 20:44:05 2014
;; MSG SIZE rcvd: 73
=>dig ae7q.hamwan.net.
@a.ns.hamwan.net.
ae7q.hamwan.net. @a.ns.hamwan.net.
; (1 server found)
;; Got answer:
NOERROR, id: 46180
;; flags: qr rd; QUERY: 1, ANSWER: 0, AUTHORITY: 1,
ADDITIONAL: 0
;ae7q.hamwan.net. IN A
;; AUTHORITY SECTION:
ae7q.hamwan.net. 3600
IN NS ns1.ae7q.ampr.org.
;; Query time: 101 msec
;; WHEN: Thu May 15 20:45:39 2014
;; MSG SIZE rcvd: 64
=>dig ns1.ae7q.ampr.org.
@ampr.org.
ns1.ae7q.ampr.org. @ampr.org.
; (1 server found)
;; Got answer:
NOERROR, id: 27978
;; flags: qr aa rd; QUERY: 1, ANSWER: 1, AUTHORITY: 7,
ADDITIONAL: 1
;ns1.ae7q.ampr.org. IN A
;; ANSWER SECTION:
ns1.ae7q.ampr.org. 3600
IN A 44.24.240.173
ampr.org. 3600 IN NS
ampr-dns.in-berlin.de.
ampr.org. 3600 IN NS ampr.org.
munnari.OZ.AU.
ns1.defaultroute.net.
ns2.threshinc.com.
ns0.comgw.net.
hamradio.ucsd.edu.
;; ADDITIONAL SECTION:
ampr.org. 3600 IN A 44.0.0.1
;; Query time: 157 msec
;; SERVER: 44.0.0.1#53(44.0.0.1)
;; WHEN: Thu May 15 20:47:46 2014
;; MSG SIZE rcvd: 263
Now, this is not correct. While I appreciate the PTR record for
44.24.240.173, it needs to point to a hostname record ("A"
or CNAME"), not a domainname record. This is not the fault
of the PTR record, but the record that it points to: The NS record
for ae7q.hamwan.net effectively declares ae7q.hamwan.net as a subdomain,
with ns1.ae7q.ampr.org as its nameserver. Now,
ns1.ae7q.ampr.org has the IP address of 44.24.240.173, but that
doesn't mean that the domain ae7q.hamwan.net is anywhere near
44.24.240.x.
The correct solution to this problem is to replace the NS record for
ae7q.hamwan.net with a reference to a host; eg:
- ae7q.hamwan.net. 3600 IN A
44.24.240.173
- ae7q.hamwan.net. 3600 IN CNAME
ns1.ae7q.ampr.org.
The administrative advantage of the CNAME is that if my IP address
changes, you don''t have to change the forward record (you'll still
have to update PTR records). The administrative disadvantage is
that the CNAME is dependent upon a different administrative
organization. However, neither solution above allows for
ae7q.hamwan.net to be a subdomain.
If you want to allow ae7q.hamwan.net to be a subdomain, you need to
lay the following foundation:
173.240.24.44.in-addr.arpa. 3600 IN
PTR ns1.ae7q.hamwan.net. ; (or ns1.ae7q.ampr.org.)
ae7q.hamwan.net. 3600 IN NS
ns1.ae7q.hamwan.net. 3600 IN A 44.24.240.173
; (if ns1.ae7q.ampr.org. is not used)
That by itself will not allow me to add subdomain records,
but it lays the foundation. I prefer creating ns1.ae7q.hamwan.net
(all three records above), as it keeps the records independent of a
different administrative organization.
If you want to get carried away, you could also add the following
record:
www.ae7q.hamwan.net. 3600 IN CNAME
