Sorry about that. I accidentally applied the wrong settings to the Metal when configuring it yesterday. It caused me to lose connection to the Metal and obviously created more of a problem than I was aware of. After doing a factory reset and re-following the client install directions, I then got it to connect properly.
FYI.. Some of the client install directions could use some tweaking as they may be misleading for some. The NTP synchronization step should probably be pushed farther to the end of the directions (after connecting to the network). Also, when configuring the local DHCP server, step 2 needs to define the network address, not the local ethernet address (i.e.
192.168.88.0/24, not
192.168.88.1/24 like it shows).
Regards,
Kyle
