Hi Tom,
Thank you for the help.
I will fix the DHCP problem.
73 David WA9ONY
Sent from my iPad
On Aug 23, 2018, at 10:35 PM, Tom Hayward <tom@tomh.us> wrote:
Looks like the problem is that your modem never got an IP address assigned because it didn't ask for one. On HamWAN that is done with a DHCP client. If you just copy/paste the command from step 22 you should be good to go:
https://hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
On Thu, Aug 23, 2018 at 9:26 PM David Haworth <davidahaworth@icloud.com> wrote:
Hi Tom,
I got out and did testing today at a new site.
My portable Mikrotik QRT 5 International terminal log is at
with commands
/ip export
/ip route check 8.8.8.8
I have updated RouterOS to 6.42.6.
I redid the HamWAN configuration.
My HamWAN Mikrotik QRT 5 client setup is at
Still traceroute and ping dod not work.
Thank you for your help.
73 David WA9ONY
On Aug 21, 2018, at 10:13 PM, David Haworth via PSDR <psdr@hamwan.org> wrote:
I will do the next time I am out.
Today I have updated the sw on the QRT 5 and reprogram the settings.
73 David WA9ONY
Sent from my iPad
On Aug 21, 2018, at 5:37 PM, Tom Hayward <tom@tomh.us> wrote:
You don't need a certificate to ping and traceroute over HamWAN. Let's try to troubleshoot. Can you send the output of
/ip export
On Tue, Aug 21, 2018, 10:07 David Haworth via PSDR <psdr@hamwan.org> wrote:
Hi,
I am new to HamWAN.
I successfully received S3.Larch/K7WAN
But, I was not successful doing a traceroute and ping.
How do I apply for a certificate?
How do I install the certificate on the portable Mikrotik QRT 5?
How do I verify the certificate is installed and is being used by the Mikrotik QRT 5?
73 David WA9ONY
