Hello -- I'm trying to set up a connection, using the instructions here:I'm getting all the way to the point where I try to do a tracert ("Connect" step 3), but nothing is coming through.My monitor shows the following -- any ideas what I should do next? Am I just not hitting the Gold Mountain node well enough?[admin@K7XST-Gold] > /interface wireless monitor 0
status: connected-to-ess
channel: 5900/5/an
wireless-protocol: nv2
tx-rate: 14.4Mbps-5MHz/2S/SGI
rx-rate: 1.6Mbps-5MHz/1S
bssid: E4:8D:8C:F1:6D:22
radio-name: Gold-S2/K7WAN
signal-strength: -76dBm
signal-strength-ch0: -78dBm
signal-strength-ch1: -80dBm
tx-signal-strength: -71dBm
tx-signal-strength-ch0: -73dBm
noise-floor: -107dBm
signal-to-noise: 31dB
tx-ccq: 54%
rx-ccq: 6%
authenticated-clients: 1
current-distance: 33
wds-link: no
bridge: no
routeros-version: 6.36
last-ip: 44.24.240.97
notify-external-fdb: no
