Steve,
Your client radio (DynaDish5) should have two DHCP configurations. DHCP Client and DHCP Server.
Your wlan interface should be configured as a “station”, and in that mode you attach the DHCP Client to the WLAN interface.
There should be no bridge on a DynaDish.
There’s nothing to bridge as you will be routing between the Wlan interface and the Ethernet interface, along with network address translation.
The client configurations on the website are generally correct for most installations.
There are some steps that would be better if in a different order, but not too far off.
Thanks to Doug, we determined that dhcp on this unit needs to point to
the "bridge" as opposed to the "wlan1" interface. That change got the
DynaDish connected last night, but there are still some DNS issues to be
resolved before it is fully functional.
Hopefully, we will end up with an improved set of step-by-step instructions.
Doug Kingston wrote on 2/13/19 12:08 PM:
> I can take care of these updates. I'll work with Steve.
> -Doug-
> On Wed, Feb 13, 2019 at 12:00 PM Steve - WA7PTM <psdr-list@aberle.net>
> wrote:
>> Is anyone maintaining the
>> https://www.hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
>> web page?
>> The reasons I ask are:
>> • Step 1 will not work as listed as the command is wrong (should be
>> "/system package update install" in RouterOS v6.43.12) and if some
>> preliminary steps are not taken (moving the default network to one
>> connected to the Internet with a "/ip address add address=a.b.c.d/xx
>> interface=ether1" command and establishing a default gateway with a "/ip
>> route add gateway a.b.c.gw" command), then the update will fail.
>> • Step 21 on a Dynadish5 results in a "failure: incompatible band and
>> channel-width" message unless "channel-width=5mhz" is added to the command.
>> • Step 22 on a Dynadish5 results in a "failure: can not run on slave
>> interface" message.
>> This last one has me stumped, and I have been unable to determine a
>> workaround. Has anyone else encountered and solved this problem?
>> Thanks,
>> Steve
>> PSDR mailing list
>> PSDR@hamwan.org
Sent from mobile.
