On 2014-04-10 19:03, Bart Kus wrote:
Yes, absolutely sure:
Ok, just checking
Can you show your modem's routing table and firewall here?  (/ip route print; /ip firewall export)
 > /ip route print
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
B - blackhole, U - unreachable, P - prohibit
 #      DST-ADDRESS        PREF-SRC        GATEWAY            DISTANCE
 0 ADS  0.0.0.0/0                          44.24.240.161             1
 1 ADC  44.24.240.160/28   44.24.240.173   wlan1-gateway             0
 2 ADC  192.168.0.0/18     192.168.3.251   ether1-local              0
> /ip firewall export
# apr/10/2014 19:20:59 by RouterOS 6.10
# software id = LTNR-CTND
/ip firewall filter
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="default configuration" connection-state=established
add chain=input comment="default configuration" connection-state=related
add chain=input dst-port=53 in-interface=wlan1-gateway protocol=udp
add chain=input dst-port=53,80 in-interface=wlan1-gateway protocol=tcp
add action=drop chain=input comment="default configuration" in-interface=wlan1-gateway
add chain=forward comment="default configuration" connection-state=established
add chain=forward comment="default configuration" connection-state=related
add chain=forward dst-port=53 in-interface=wlan1-gateway protocol=udp
add chain=forward dst-port=53,80 in-interface=wlan1-gateway protocol=tcp
add action=drop chain=forward comment="default configuration" connection-state=invalid
/ip firewall mangle
/ip firewall nat
add action=masquerade chain=srcnat comment="default configuration" out-interface=wlan1-gateway to-addresses=0.0.0.0
add action=masquerade chain=srcnat dst-port=53 out-interface=ether1-local protocol=udp to-addresses=192.168.0.250
add action=masquerade chain=srcnat dst-port=53,80 out-interface=ether1-local protocol=tcp to-addresses=192.168.0.250
add action=dst-nat chain=dstnat dst-port=53 in-interface=wlan1-gateway protocol=udp to-addresses=192.168.0.250
add action=dst-nat chain=dstnat dst-port=53,80 in-interface=wlan1-gateway protocol=tcp to-addresses=192.168.0.250
Happy hunting ...
