I was thinking more about the strength/stability of Haystack.  When I was connecting up the hospital in Monroe I thought I remembered being told that Haystack was marginal due to the split from Paine and one of the other links being interfered with (Amazon?) – I might be mixing my site memories.  If it’s marginal I would like to see Haystack solidified (if possible) as I have Evergreen on there and it’s my #1 option for Everett Clinic.
From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Nigel Vander Houwen
Sent: Monday, March 13, 2017 10:48 PM
Subject: Re: [HamWAN PSDR] Haystack Site Outage
Rob,
Nigel,
If memory serves me correctly I think we swung the Paine dish to cover the new Victoria site last year.  Are there any plans to install a separate dish to optimize both links once the weather and access improve?
Rob / NR3O
Sent: Sunday, March 12, 2017 11:24 PM
Evening Everybody,
  • They found some misbehaving equipment that had a huge draw (>400W continuous) on the power system up there, overwhelming the solar generation capacity, draining the batteries, and causing the generator to run more than it should have been needed, and then run out of fuel.
  • They brought up 40 gallons of fuel that was brought partway up the mountain on the last trip.
  • Bart replaced the Haystack-S3 modem to see if it would fix an issue we’re seeing with non-symmetric signal strengths. It didn’t resolve the issue, so we’ll revisit that issue again later.
  • Replaced the RJ45 connector for the Haystack-S3 modem that may have been the cause for the earlier Haystack-S3 outage.
Hello All,
