Bart,
Thanks for the response. I'll give it proper attention later tonight.
K7QJ
On Wednesday, May 6, 2020, 04:48:53 PM PDT, Bart Kus <me@bartk.us> wrote:
It looks like connect-to can take either a name or an address:
[eo@CR1] /interface ovpn-client> add connect-to=
ConnectTo ::= Address | Name
  Name -- string value
  Address ::= A.B.C.D    (IP address)
Have you tried having your dynamic IP register with DNS, and then have
the ovpn-client connect to that DNS?
On the ovpn-server side, there's instructions from our Open Peering
Policy page on how to configure Dynamic DNS:
http://hamwan.org/Labs/Open%20Peering%20Policy.html#optionally-configure-dynamic-ip-support
Although Mikrotik also has their own "ip cloud" dynamic dns thing:
https://wiki.mikrotik.com/wiki/Manual:IP/Cloud
On 5/6/2020 2:36 AM, Rob Martin via PSDR wrote:
> Hello,
> I would appreciate some assistance in writing a script to run in a Mikrotik router.
> I am trying to get a remote Mikrotik router to phone home by establishing an ovpn tunnel. I am able to deliver my local IP address to the remote router, and store it in its firewall address list. My local IP changes occasionally.
> The ovpn tunnel setup does not seem to have a way to directly use a variable for the connect-to address. I need help with a script to perform this.
> Here are details of the project:
> 1.  Add an entry to the list to simulate a separate process that adds entries automatically. I have the this part working already.
> /ip firewall address-list
> add
>    list=K7QJ
>    address=97.11.22.33
> 2.  Add the following ovpn tunnel to simulate an earlier entry in the router setting up the tunnel. This is a slightly edited version of a working tunnel.
> add
>    add-default-route=yes
>    certificate=cert_export_client_QJ.crt_0
>    cipher=aes256
>    comment="Tunnel to K7QJ TS "
>    connect-to=12.34.56.78          **** placeholder IP
>    disabled=yes
>    mac-address=00:11:22:33:44:55
>    name=Tnl_K7QJ
>    password=abcdefg
>    user=K7QJ_A
> 3.  Here is where I need help.....  Create a script that will scan the address list, locate the entry K7QJ, and put the address value (97.11.22.33) in a variable.
> 4.  Add lines to the script that will edit the above tunnel setup as follows:
>    connect-to=97.11.22.33      **** where the IP is recovered from the variable
>    disabled=no                            **** and the tunnel goes live.
> Thanks for any help you might be able to offer.
> Rob
> K7QJ
