That's great! It also confirms the software I wrote to let me know when new people connect is working. I got an email at about 6:30.
Tom
Thanks, Tom! A bit of wiggling and a better spot and I got up to -80 dBm
and connected flawlessly.
On Mon, Nov 7, 2016, at 09:31 PM, Tom Hayward wrote:
> Your signal just isn't strong enough to connect. The sensitivity
> threshold on that receiver is specified at -95 dBm, but the -87 dBm
> you're seeing is about the weakest I've ever seen anyone able to
> connect. A usable signal would be above -80 dBm and a good signal
> would be -70 dBm and above. It would be great if you could come up
> with an additional 17 dB, either through improved aiming, mounting
> location, or a higher gain antenna.
> Tom KD7LXL
> On Mon, Nov 7, 2016 at 8:36 PM, Eric Wolak <ag6ie@wolak.net> wrote:
> > Howdy,
> > I'm new to the area and excited to get involved in PSDR. I got myself a
> > MikroTik SXT 5nD r2 and I have good line of sight to the CapitolPark
> > cell. After working my way through the Client Node Configuration
> > instructions, I can see the AP with an SNR of 38 dB, but I'm unable to
> > connect.
> > [admin@AG6IE-CapitolPark] > /interface wireless scan 0
> > ADDRESS SSID CHANNEL
> > SIG NF SNR RADIO-NAME
> > ROUTEROS-VERSION
> > A RT B D4:CA:6D:30:75:89 HamWAN 5920/5/an
> > -87 -125 38 CapitolPark-S1/K7WAN
> > [admin@AG6IE-CapitolPark] > /log print
> > 00:50:58 wireless,info D4:CA:6D:30:75:89@wlan1: failed to connect, on
> > 5920000, registration timeout
> > [admin@AG6IE-CapitolPark] > /interface wireless print
> > Flags: X - disabled, R - running
> > 0 name="wlan1" mtu=1500 l2mtu=1600 mac-address=4C:5E:0C:5B:A6:FB
> > arp=enabled interface-type=Atheros AR9300 mode=station-bridge
> > ssid="HamWAN" frequency=5920
> > band=5ghz-onlyn channel-width=5mhz scan-list=HamWAN
> > wireless-protocol=nv2 vlan-mode=no-tag vlan-id=1 wds-mode=disabled
> > wds-default-bridge=none
> > wds-ignore-ssid=no bridge-mode=enabled default-authentication=yes
> > default-forwarding=yes default-ap-tx-limit=0
> > default-client-tx-limit=0 hide-ssid=no
> > security-profile=default compression=no
> > Did I miss some setup step? Do I need to get my MAC address whitelisted
> > or something?
> > I wiped the settings and started over, and now I'm getting a different
> > failure:
> > [admin@AG6IE-CapitolPark] /interface wireless> scan 0
> > failure: other tool running
> > I rebooted, and then tried to use the WebFig interface to scan and
> > connect. Again I saw the network, but the connection never succeeded.
> > Got this in the log:
> > 00:22:35 wireless,info D4:CA:6D:30:75:89@wlan1: failed to connect, on
> > -Eric AG6IE
> > _______________________________________________
> > PSDR mailing list
> > PSDR@hamwan.org
> > http://mail.hamwan.net/mailman/listinfo/psdr
