/interface wireless monitor 0
[admin@WA9ONY-LARCH] > /interface wireless monitor 0
status: connected-to-ess
channel: 5880/5/an
wireless-protocol: nv2
tx-rate: 1.6Mbps-5MHz/1S
rx-rate: 1.6Mbps-5MHz/1S
bssid: 64:D1:54:6A:64:26
radio-name: S3.Larch/K7WAN
signal-strength: -68dBm
signal-strength-ch0: -72dBm
signal-strength-ch1: -71dBm
tx-signal-strength: -70dBm
tx-signal-strength-ch0: -72dBm
tx-signal-strength-ch1: -73dBm
noise-floor: -125dBm
signal-to-noise: 57dB
tx-ccq: 6%
rx-ccq: 6%
authenticated-clients: 1
current-distance: 22
wds-link: no
bridge: no
routeros-version: 6.42.3
current-tx-powers: 6Mbps:27(27/30),9Mbps:27(27/30),12Mbps:27(27/30),18Mbps:27(27/30),24Mbps:27(27/30),
36Mbps:27(27/30),48Mbps:25(25/28),54Mbps:24(24/27),HT20-0:27(27/30),HT20-1:27(27/30),
HT20-2:27(27/30),HT20-3:27(27/30),HT20-4:27(27/30),HT20-5:27(27/30),HT20-6:25(25/28),
HT20-7:23(23/26)
notify-external-fdb: no
On Aug 29, 2018, at 10:21 PM, Mark Weisenfeld <mark@weisenfelds.com> wrote:I have this 25/27 dB MikroTik LHG XL HP5 device that I can move around Tumwater (south Olympia) and measure the signal from Capitol Peak at various places at around 10 miles._______________________________________________The last two nights I have reset and completely reconfigured the device and I still cannot register any signal from Capitol Peak in several locations.After I do a reset, and before I reconfigure the routerOS, I see that it scans all the regular 802.11 channels and registers a whole list of local APs. Then I go on to finish inputting all the settings and it becomes silent. I can't get a single 5.8 Ghz signal to show up from several locations around my local area.So has something changed?Do I need to apply some other setting?Did HAMWAN suddenly change all their frequencies? (smirk)Is Capitol Peak asleep? (smirk²)I could assume that somehow my device has crapped out, after less than a year an no real usage, ever. I used to get -91dB and similar from scanning at my home and at the local DEM, but now nothing. It shows all 6 channels enabled, but a scan shows nothing.
Is there a way to test this thing? Could I enter an additional standard USA 5Ghz channel and see my own 5Ghz wireless show up?Thanks y'all.**************************
