Hmm, let's see:
  1. If you happen to get root access on any of my Linux boxes and do "rm -rf /" or "rm -rf /bin" or "rm -rf /sbin" or "rm -rf /sys" or "rm -rf /usr" or "rm -rf /lib" (or any other modifications to those directories), nothing will happen.  Depending upon what I've been doing recently, "rm -rf /etc" (or other directories) may or may not work.  When I used SCSI hard drives (which back then typically had a jumper to force read-only access), that was enforced by hardware in addition to a software configuration.  Whether I make similar mods to the MikroTik OS configuration, remains to be seen.
  2. I run bind (named), ntpd, and postfix in a chroot environment.
  3. SSH does not run on port 22 (nor does it run on a port # > 1024).  PostgreSQL is not available on port 5432.  Postfix does not allow submissions on port 25.  I don't use self-signed keys.  I don't type root passwords.  Etc.
  4. I've run externally-available DNS servers for 15 years, and I've never allowed recursive queries outside my LAN.
  5. Before I installed FiOS, I asked the (then) Verizon rep whether if could support idiot customers with had back-door access to the provided modem, and when the answer was yes, I set up a DMZ.  When people visit my house and need WiFi or wired access, they're in the DMZ.
I have run various versions of Windows for decades, and until recently without anti-virus software (some of it is just soothing or alarming junk), without ever getting a virus.  However, before I made the above modifications (except the last) to my Linux boxes over a decade ago, I did have an otherwise-secure Linux box compromised by a vulnerability in ISC bind: my server was #3 in a five-stage leapfrog attack on a bank.  This was before the above modifications over a decade ago.  Since then, I've been paranoid.  You too can be paranoid, with only a little effort (or experience).
Oh, and when I was run running a public NTP server (my one serious mistake; see: http://www.ultimeth.com/Abandon.html ), I had people accessing my NTP hostname without getting permission, so I changed the hostname (and let authorized users know), and then pointed the old hostname to 127.0.0.1 (I have other "useful" but unsupported services similarly configured).  Boy, did that make one person mad;  he complained to the NTP mailing list (which was somehow unsympathetic).  I guess entitlement is alive and well on the Internet ...
So yes, I'll take the risk that a change to the HamWAN network will render my link temporarily unusable.
On 2014-03-11 17:11, Jeff Francis(tm) wrote:
If you put your modem outside of your firewall (which is where mine is, in spite of the fact that I haven't successfully connected yet), your exposure is no worse than being attacked from another host connected to the HamWAN network*.  You *do* have a firewall on your network, right? ;^)
* Well, ok, speaking as a professional security geek (which is what I do for a living), it *is* in fact very slightly worse.  Assuming the firmware of the modem could be compromised to launch attacks, it's a higher-bandwidth lower-latency connection to pound on your network from, which, in theory, is less secure.  But given the speed of the HamWAN network, the delta is pretty small, and given that the modems run a semi-proprietary (and fairly uncommon) OS, the odds of the modem itself becoming a leapfrog platform for staging attacks are pretty insignificant.  And again, assuming you've got a halfway decent firewall in the middle (ie, not just a cheap consumer device that does NAT, but an actual firewall), I wouldn't worry about it.
Jeff N0GQ
On Tue, Mar 11, 2014 at 4:27 PM, Nigel Vander Houwen <nigel@k7nvh.com> wrote:
To add to what Cory said,
The goal is not to remove control or access from the user. It's simply for network management. It's very much an experimental network, so if you choose not to allow admin accounts on your modem, the network may change and you will be responsible for maintaining it yourself.
I'd also like to bring up a parallel with other commercial ISPs. You end up in the same situation. For example, with comcast, you can either rent a modem from them, which they have full admin control of, and may not give you any access at all, or you buy a modem yourself, and configure it to work with them, and any issues or changes are your own responsibility.
For us the problem is far more significant. The HamWAN network is changing and evolving all the time, unlike a network like comcast's which is relatively stable. The methods of connecting / authenticating to the network will change, and you should be prepared for that if you decide that allowing a few trusted users on your modem is an unacceptable risk, despite these users having full administrative access to ALL of the rest of the HamWAN network routing your packets.
In any case, as Cory said, it is your choice, but the recommended one is what's documented on the wiki instructions.
Nigel K7NVH
