Duane,
Are you looking to setup a point to point link of your own independent of HamWAN, or connecting these dishes to HamWAN to connect 2 (or more) separate sites?
If doing a separate link, one of the radios needs to be configured as an access point (ap-bridge) and the other as a client (station). The rest of the wireless parameter should be pretty much the same. You can use the wireless scan and monitor functions to see whether the dishes are “seeing” each other.
Shoot me some more info on your setup or email me your configs and I can see what else I can spot that might help.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Duane Braford via PSDR
Sent: Friday, November 10, 2023 7:28 PM
Subject: [HamWAN PSDR] Point to Point Link
We are looking at replacing an old repeater link, what we are losing access to.
We are looking at leveraging HamWAN to provide a path for further growth, and possibility connection to HamWAN in the further.
There is a possibility of a third node being able to connect to the system.
I am assuming I will have to set up static routing.
Currently I have a pair of RB912UAG-5HPnD-OUT that I am trying to get to talk with each other.
I have looked at you examples of Client configuration and the Point-to-Point configuration.
I believe I am missing something, I still can't get them to calk to each other.
Regards,
Duane
WB7ROZ
