Thanks for the excellent data. If you'd like to have more fun, I'd
also like to point out that all of our routers should be running
bandwidth-server instances. This means you can make actual RF
throughput measures on a per-hop basis. Try it to your first hop:
[eo@WA6PXX-MercerIs] /tool bandwidth-server> /tool traceroute
8.8.8.8
# ADDRESS LOSS SENT LAST
AVG BEST WORST STD-DEV STATUS
1 44.24.240.33 0% 1 7.6ms
7.6 7.6 7.6 0
2 44.24.240.6 0% 1 3.6ms
3.6 3.6 3.6 0
3 44.24.240.66 0% 1 24.2ms
24.2 24.2 24.2 0
4 44.24.241.113 0% 1 56.8ms
56.8 56.8 56.8 0
5 0% 1 0ms
bandwidth-test direction=receive 44.24.240.33
status: running
duration: 12s
rx-current: 7.1Mbps
rx-10-second-average: 7.0Mbps
rx-total-average: 6.9Mbps
lost-packets: 143
random-data: no
direction: receive
rx-size: 1500
and so on... By the third hop, you may begin to notice the
problems:
bandwidth-test direction=receive 44.24.240.66
status: running
duration: 7s
rx-current: 204.0kbps
rx-10-second-average: 921.8kbps
rx-total-average: 921.8kbps
lost-packets: 34
random-data: no
direction: receive
rx-size: 1500
Of course your throughput will be limited by existing network load.
You can monitor that using our public traffic graphs:
http://monitoring.hamwan.net/cacti/
The login / password is hamwan / hamwan. (I though I had gotten rid
of it, but it persists.) These only update once every 5 minutes, so
they're not as handy as they could be for manual testing. In most
cases though, the network is idle enough that you won't need them,
and bandwidth-test results will be highly indicative of link speed.
Be sure to give the links at least 30 seconds to come up to speed.
They default to sitting at a lower speed when they're not being
asked to move lots of data, and then they train up on higher speeds
as required. This is to maximize their reliability when only low
data rates are required.
Oh, and you will not be able to do a bandwidth-test to the edge
routers. These have firewall rules that prevent bandwidth-testing.
We should really fix that at some point.
Speaking of fixing, I've started writing some software last night to
help us optimize the QA-CP and QA-Westin links. Both of these
sometimes affect your connection. As Tom mentioned, QA-CP is
affected by a poor path to the side of a dish, but QA-Westin is
affected by Amazon constructing a new building right in the signal
path. You can view the path obstacle here:
http://cam.westin.hamwan.net/
If we can't get either of these links to perform acceptably, we can
manually give them a lower priority on the network. The QA-CP link
might be helped a lot just by installing a higher gain modem @ QA
and/or rotating/upgrading the dish @ CP. The QA-Westin problem is a
little harder. So far we've reduced the bandwidth of QA-Westin to
help it out, and you can see the signal increase in the associated
graph:
http://monitoring.hamwan.net/cacti/graph.php?action=view&local_graph_id=439&rra_id=all
But it doesn't seem to have helped speeds at all, so now we need to
do some interference-avoidance work. I hope to have that software
finished this week.
The last problem we should address here is the apparent route
flapping inside the network. We don't have any good tools in place
to monitor that, and it looks to be affecting your path. While this
shouldn't result in outages for you, it does indicate marginal
network stability, so it's a problem we need to look into. I do
have designs to monitor this and mitigate it, but they're slightly
longer-term.
On 4/4/2016 10:42 PM, David Giuliani
wrote:
Thanks for the suggestions today, guys. I used WinMTR to monitor
routes, and ran some speed tests during the day. 5.9GHz link has
remained strong at about 50dB SNR aimed at CapitolPark. Here’s a
performance report:
~12 noon: had one recording of 6.5Mbps download
- cool!
2pm-3:15pm
ping
42-55mS
down:
1.3-1.74 Mbps
up:
1.45-1.6 Mbps
3:20: no connection possible
3:23-3:35 similar performance to 2-3:15
4:10: performance faltered, and within a couple
minutes the routing adjusted and restored performance.
(Note time in file name)
<Mail Attachment.png><Mail Attachment.png><Mail Attachment.png>
7:35pm: ping: 53mS, down = 1.06Mbps, up =0.9Mbps
= lowest so far today
8:44pm: ping: 86mS, down=0.8Mbps and erratic;
up=1.1Mbps
10:22pm: ping=24mS (fast!), down=1.46Mbps,
up=2.0Mbps
Note the two “no response” entries, but similar
link performance as earlier in the day, plus faster ping.
I hope this helps you guys figure out how the
system’s working. As far as I’m concerned, the 1.5Mbps
speeds are find for WINLINK, it’s just the availability
reliability that’s concerning.
<PastedGraphic-3.tiff>
WA6PXX, Mercer Island
On Apr 4, 2016, at 1:59 PM, Bart Kus <
me@bartk.us> wrote:
