I have this Dynadish:  DynaDish5, ID: RBDynaDishG-5HacD, FCC ID: TV7DyHADISHGAC.  It works fine with HamWAN. I have made a 23 mile connection from my house to Gold Mountain. However, I use the 2 foot dish for my regular Gold link, as it has a bit more gain. Just remember you must get the international version, not the US version. https://www.streakwave.com/itemdesc.asp?ic=DynaDishG%2D5HacD&eq=&Tp=&o1=0
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Stephen Kangas
Sent: Monday, September 14, 2020 4:03 PM
Subject: Re: [HamWAN PSDR] Advice for parts for a portable setup
Carl, I recall reading on the forum that 802.ac antennas do not play well with the HamWan cell site sector antennas.  Dynadish 5 is a 802.ac device.  Have you experienced any problems, and which HamWan sites have you connected to with your Dynadish?
(Note: the Dynadish 5 is about twice the price of the LHG 5hp, and slightly less gain.)
Nice use of a studio light stand there.  I have a spare inexpensive 5ft PA speaker stand with integrated 1.25in “mast” that’s perfect for use with the MikroTik Quickmount Pro LHG adjustable az-el mount made for the LHG series.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Carl Leon
Sent: Monday, September 14, 2020 3:33 PM
You need a balance between highest performance and portability. My recommendation would be for a Dynadish5 for any type of portable application. It will run nicely on standard 12V power (your ethernet run will not be very long, so voltage drop isn’t the concern it is on fixed installations where you want 24V).  You will have an ethernet jack out of the Dynadish which can be used to feed whatever your installation wants are (a switch with multiple ethernet outputs, a wireless access point, both). The Dynadish includes a built in Mikrotik router which will serve DHCP with NATing to a 192.168.88.xxx address if you use standard HamWAN programming suggestions.
I have some 10 foot PBL Studio Light Stands which are good tripod stands.
As to maximizing data speeds, that is mostly a function of your signal levels to the sector panel you connect to.  Longer distance shots are going to give you lower speeds. The Dynadish is a good compromise between maximum signal and portability. You can get smaller, lighter weight equipment, and you can get heavier, more difficult to set up and aim equipment.
Make sure you get the international, or “Rest Of World – ROW” version of the Dynadish5. The US version can’t get to HamWAN frequencies.
Sent: Monday, September 14, 2020 2:33 PM
Subject: [HamWAN PSDR] Advice for parts for a portable setup
Hello to the group!
I am on Bainbridge Island, and I am looking into a portable setup to experiment with from different locations.
While there is a lot of useful gear info on the website and on this listserv, I want to make sure that I don’t end up getting something that doesn’t maximize data speeds or will be obsolete in a year.
I am looking for advice for a complete portable system. I can make use of a power supply and tripod that I already have, although I’d be interested on input on that, as well.
Thanks in advance for your help with this.
-Lionel
K7BIX
