I'm not sure that's a fair assessment.  The link to SnoDEM is only -77dBm and only on hpol (vpol is -90 ish).  Here's the perf that link gets:
[eo@SnoDEM.Haystack] /interface wireless registration-table> /tool bandwidth-test 44.24.242.6 direction=receive
                status: running
              duration: 30s
            rx-current: 4.4Mbps
  rx-10-second-average: 4.7Mbps
      rx-total-average: 4.4Mbps
          lost-packets: 478
           random-data: no
             direction: receive
               rx-size: 1500
[eo@SnoDEM.Haystack] /interface wireless registration-table> /tool bandwidth-test 44.24.242.6 direction=transmit
                status: running
              duration: 30s
            tx-current: 11.9kbps
  tx-10-second-average: 27.6kbps
      tx-total-average: 26.4kbps
           random-data: no
             direction: transmit
               tx-size: 1500
That TX path makes the link useless.  Better to turn it off!  Or maybe ditch the weak polarity.
Then there's Nigel's + my link (I'm NOT uplinking right now), both sitting @ -81dBm, which is pretty low.  Or at least we were.  I see Nigel's @ -68dBm right now.  I don't know how to explain that.  Here's the link speed:
[eo@Haystack-S3] /interface wireless registration-table> /tool bandwidth-test 44.24.241.78 direction=receive
                status: running
              duration: 30s
            rx-current: 21.3Mbps
  rx-10-second-average: 19.4Mbps
      rx-total-average: 18.8Mbps
          lost-packets: 1720
           random-data: no
             direction: receive
               rx-size: 1500
[eo@Haystack-S3] /interface wireless registration-table> /tool bandwidth-test 44.24.241.78 direction=transmit
                status: running
              duration: 30s
            tx-current: 25.2Mbps
  tx-10-second-average: 26.7Mbps
      tx-total-average: 24.4Mbps
           random-data: no
             direction: transmit
               tx-size: 1500
But of course that's on S3, so he'll be sharing time domain with NR3O's uplink, so cut that speed at least in 1/2, and probably more when the -81dBm conditions return.  Then we have a link to QueenAnne:
[eo@QueenAnne.Haystack] > /tool bandwidth-test 44.24.242.39 direction=receive
                status: running
              duration: 30s
            rx-current: 113.9Mbps
  rx-10-second-average: 124.3Mbps
      rx-total-average: 104.6Mbps
          lost-packets: 6234
           random-data: no
             direction: receive
               rx-size: 1500
[eo@QueenAnne.Haystack] > /tool bandwidth-test 44.24.242.39 direction=transmit
                status: running
              duration: 30s
            tx-current: 76.2Mbps
  tx-10-second-average: 76.7Mbps
      tx-total-average: 58.4Mbps
           random-data: no
             direction: transmit
               tx-size: 1500
Which as you can see is pretty sweet, but it's then choked by the QueenAnne-Westin link when it comes to reaching the Internet:
[eo@QueenAnne.Seattle] > /tool bandwidth-test 44.24.242.35 direction=receive
                status: running
              duration: 30s
            rx-current: 3.2Mbps
  rx-10-second-average: 2.9Mbps
      rx-total-average: 2.9Mbps
          lost-packets: 28
           random-data: no
             direction: receive
               rx-size: 1500
[eo@QueenAnne.Seattle] > /tool bandwidth-test 44.24.242.35 direction=transmit
                status: running
              duration: 30s
            tx-current: 4.5Mbps
  tx-10-second-average: 4.3Mbps
      tx-total-average: 4.3Mbps
           random-data: no
             direction: transmit
               tx-size: 1500
The Victoria link doesn't have direct peering to the Internet, it VPNs back to the Westin.  Last time I measured, it does 15Mbit one way and 30Mbit the other way, and I don't know what the limits are on the cable modem VPN.
So no, I would not consider Haystack as having good connectivity.  We need to get Victoria onto a different cell site (yet to be constructed) so we can point the dish back at SnoDEM.  Having the dish pointed back @ SnoDEM will also allow K7NVH's uplink to be collinear and get out of the -81dBm muck.  We also need to fix QueenAnne's connectivity.  This might have some chance of success as we get more access to the Capitol Park site.  We could either up CP's connectivity with CA and Baldi, and route via Tukwila, or we could connect CP directly to Haystack and route via Tukwila.  QueenAnne may also be able to link with Gold.
So if you're seeing slow connectivity, on the order of 5Mbit or so, now you know why.
PS: I disabled ch1 on Haystack.SnoDEM and the slow Haystack->SnoDEM transfer speeds didn't stop.  Now I suspect it's the brand new 5GHz WiFi that got installed all over that building.  Need to do more research and maybe find a better frequency.
On 3/13/2017 11:27 PM, Rob Salsgiver wrote:
Cool – thanks.  Once again it seems my mind is the item suffering the outages these days….
Sigh
From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Nigel Vander Houwen
Sent: Monday, March 13, 2017 11:21 PM
Subject: Re: [HamWAN PSDR] Haystack Site Outage
Haystack is pretty well connected as well, it has links to Vancouver, Paine, and Queen Anne, as well as Bart and myself are uplink nodes connected to Haystack.
On Mar 13, 2017, at 23:19, Rob Salsgiver <rob@nr3o.com> wrote:
I was thinking more about the strength/stability of Haystack.  When I was connecting up the hospital in Monroe I thought I remembered being told that Haystack was marginal due to the split from Paine and one of the other links being interfered with (Amazon?) – I might be mixing my site memories.  If it’s marginal I would like to see Haystack solidified (if possible) as I have Evergreen on there and it’s my #1 option for Everett Clinic.
Sent: Monday, March 13, 2017 10:48 PM
Rob,
Nigel,
If memory serves me correctly I think we swung the Paine dish to cover the new Victoria site last year.  Are there any plans to install a separate dish to optimize both links once the weather and access improve?
Rob / NR3O
Sent: Sunday, March 12, 2017 11:24 PM
Evening Everybody,
  • They found some misbehaving equipment that had a huge draw (>400W continuous) on the power system up there, overwhelming the solar generation capacity, draining the batteries, and causing the generator to run more than it should have been needed, and then run out of fuel.
  • They brought up 40 gallons of fuel that was brought partway up the mountain on the last trip.
  • Bart replaced the Haystack-S3 modem to see if it would fix an issue we’re seeing with non-symmetric signal strengths. It didn’t resolve the issue, so we’ll revisit that issue again later.
  • Replaced the RJ45 connector for the Haystack-S3 modem that may have been the cause for the earlier Haystack-S3 outage.
Hello All,
