OK, over the last three weeks both the TX and RX signal levels have dropped 8dB; see:
http://www.ae7q.com/misc/media/5.9GHz/2014-07-xx.png
While this could be due to vegetation, the drop (somewhat gradual this time) looks suspiciously like the previous two drops of 8dB (see prior messages below). On Friday I noticed that MicroTik had a new firmware release, v6.17, and I upgraded to that. That fixed an NTP bug introduced in v6.14 but made no difference in dBm levels, so Sunday evening I downgraded to v6.13. That downgrade/reboot was successful, but also made no difference. So, I did a second reboot in preparation for upgrading back to v6.17 (using the same scenario as below).
This time, however, "presto!" (the results below) does not quite apply. The 5SHPn shows a power-on LED, and when connected to a switch, shows an electrical network LED. However, the 5SHPn is inaccessible via Ethernet (using Winbox to access via both by last IP address, and by MAC address). PINGs fail; there is no corresponding entry in the ARP table. I can hold in the reset button while power-cycling the 5SHPn, and I get the flashing power LED indicating a "reset configuration" is happening, but to no avail: Winbox is unable to connect to the 5SHPn.
This is the third time I've had this 8dB drop, and the second time I've had to go to the roof to reset the radio. So, I've removed the antenna from the roof. So, unless someone has a bright idea, the 5SHPn and the 31dBi dish antenna are available for $120 total. I'd like to sell them as a unit, because I've got a really nice (but easily removable) taped seal of the antenna/radio connection. If you can't get the radio to work, you're only out $20.
425-338-4276 (home)
425-359-4276 (cell)
On 2014-06-13 18:29, Dean Gibson AE7Q wrote:
Going back to v6.13 didn't improve anything, but it did seem to get rid of the occasional variations in voltage (from 13.5v down to 12.8v) that SNMP was reporting to "The Dude" software. So, after letting v6.13 run for couple hours with no improvement, I reinstalled v6.15.
Presto! Instant dBm improvement back to my normally observed values. Here are links to SNMP graphs of the drop @9:30am, and the rise at 17:48pm. Of course, you can also see this in Nigel's Cacti reporting, albeit with less horizontal (time) resolution.
http://www.ae7q.com/misc/media/5.9GHz/2014-06-13_0940.png
http://www.ae7q.com/misc/media/5.9GHz/2014-06-13_1740.png
Note that the reported sudden dBm "rise" to -60dBm (the upper limit I've imposed to keep the graph scale reasonable) on two occasions in the second graph, is when I upgraded and then reconfigured the radio (from a cut-&-paste script), and should be ignored.
Note that a very similar scenario occurred several months ago, when I upgraded from v6.10 to v6.12.
Of course, today is Friday the 13th. Maybe Jason is responsible.
On 2014-06-13 12:28, Dean Gibson AE7Q wrote:
On 2014-06-13 12:13, Cory (NQ1E) wrote:
Did it rain on those trees you're pointing at around then? :)
On Fri, Jun 13, 2014 at 12:12 PM, Dean Gibson AE7Q <hamwan@ae7q.com> wrote:
This morning (well after the update to v6.15 last night) just after 9:30am, I saw a 8dB drop in both TX and RX signal levels, which persist at this time. I did a "reset configuration", which did not solve the problem.
Did anyone do a change at Paine sector 2 around 9:30am?
It's been raining gently all morning. Last night it rained a bit harder, and I saw no significant or unusual variation. I'm going back to v6.13 to see if that changes anything.
The drop was very sudden. I have that antenna connection very well sealed, I thought, and the Ethernet cable runs uphill to get into the eaves. I did a cursory visual check of that this morning.
On 2014-05-04 13:00, Dean Gibson AE7Q wrote:
OK, everything is back working, and I have my dBm back!!
Not a comedy of errors, but two factors intertwined to create this problem:
- Since configuring the radio after a configuration reset requires the use of WinBox (until you get IP addresses set up), I moved the network connection from the radio to its normal router on the DMZ, and connected it to a router on my LAN via an extension Ethernet cable and a "dual-RJ-45-jack adapter". The port light on the router associated with the radio connection was off. This morning when I went to disconnect the cables, I saw the port light on the router flash momentarily. Junked the dual-RJ-45 adapter and used another one (I had previously tried a different cable), and I had WinBox access to the radio! Everything worked except for the LEDs ...
- After much more screwing around, I found out that for version 6.12, the LEDs are not configured by default !!! Remember, I had done a "reset-configuration" ...
So, for others that update to v6.12, here are the relevant lines in the setup:
/system leds add type=interface-status interface=ether1-local leds=user-led
/system leds add type=wireless-signal-strength interface=wlan1-gateway leds=led1,led2,led3,led4,led5
Now that I know I can configure the LEDs with other options, I'll try some.
I have no clue as to why my dBm dropped, and why I now have my prior values back ...
-----Original Message-----
Well, this did not end well. ... I decided to reset the configuration (using the command line) ... it appears to have "bricked" the radio.
It draws about 160ma (about the value from a week ago, when I first measured it). There is no light on the side of the unit, and the Ethernet port is dead.
