Hi Jessie,
I’ve seen the responses so far and I think you deserve a little more.
5 GHz requires unobstructed Line of Sight (LoS) this means if you can’t see it, you can’t work it (reliably). While it is wireless and penetrates through things, the process for going
through things causes signal distortion, degradation, attenuation, fading, and multipath. All bad things when dealing with data over the air. Also, not sure what your planned use would be, but HAMWAN isn’t your typical internet service provider.
Out of your options #1 seems the best, but if those windows are tinted, then, you are SOL.
The LHG HP5 is a great choice:
MikroTik Routers and Wireless - Products: LHG HP5
You will likely desire a mounting option:
MikroTik Routers and Wireless - Products: solidMOUNT
I recommend Streakwave
MikroTik RBLHG-5HPnD-XL 5GHz LHG 27dBi 802.11an 2x2 ROW (streakwave.com) This is the high-power version for $81
MikroTik solidMOUNT Advanced Pole Mount Adapter for LHG (streakwave.com): Mount for $27.55
You will need to email a copy of your amateur license to William Book
William.Book@streakwave.com to prove you’re a ham.
Super easy to work with. Shipping is where they will get you, so be ready for that.
My club runs 3 dishes, all purchased from Streakwave with the help of Bill.
Feel free to reach out direct if you need anything else.
Jamie Hughes
WA7JH
Phone:
(360) 340-8886
Jesse Victors via PSDR
Sent: Friday, May 28, 2021 9:51 AM
To: psdr <psdr@hamwan.org>
Hey everyone!
2) if 5 GHz can pass through tree leaves, I could mount the dish on the mast holding the center of my HF fan dipole, as shown here:
https://www.qrz.com/db/kj7yls At a height of 30 feet it might be able to connect with Paine.
As far as antennas go, the LHG 5 seems to have pretty good performance, is within my hobby budget, and should work for the links that I have in mind, yes? It should also be lighter and more wind-resistant since its hollow. I should be able to mount that on
a pole, connect PoE, and then work on the routing, correct? If this is a decent choice, where is a good place to order the International edition?
Jesse
KJ7YLS
