Ran 3 new sector antennas through their paces:
The results are underwhelming.  The ITelite was looking very good on FR and absolute gain, but then it totally fell apart on the radiation pattern.  The RF elements has very poor gain @ the upper ham frequencies.  The radiation pattern of this antenna is quite good though, if only we were using it lower down.  The Teletronics has pretty low gain @ the upper ham frequencies, but more importantly, the radiation pattern is just broken.  Almost a -20dB null @ 320 degrees.
I've updated the Antenna Shootout page to add the results of these 3 new antennas.  Had to normalize them to the 100m range standard levels.  I also re-measured many of the other sector antennas on the 8m range and normalized their results to 100m range equivalents.  Things are measuring mostly consistently.  The largest delta is the 16dBi Ubiquiti sector, which lost 2dB of gain in the re-test.  I re-ran the radiation pattern on it as well, since I noticed the peak gain involved adding a bit of up-tilt to compensate for the built-in electrical downtilt.  The new radiation pattern is not so bad.
So far the best sector is looking like that Laird I originally bought.  Need to rig up vertical plane radiation pattern measurement capabilities.  A narrow vertical beamwidth can kill a decent horizontally behaving sector.  Unidirectional antennas are so much easier to deal with!
