You bet.  Here are the exact coordinates of the antenna location: 48.056665, -122.136877
One question to you, what polarization should I be using?  I assumed it is vertical, which is how I currently have my 2 foot ARC dish antenna hooked up.
Thank you,
Kyle
On Sun, Feb 22, 2015 at 1:15 PM, Bart Kus <me@bartk.us> wrote:
Kyle,
On a related subject, can we get your node's GPS location so we can add it to the map and real-time signal reporting?
On 2/22/2015 12:59 PM, Tom Hayward wrote:
On Sun, Feb 22, 2015 at 12:04 PM, Kyle Burgess <kd7iyt@gmail.com> wrote:
Sorry about that.  I accidentally applied the wrong settings to the Metal
when configuring it yesterday.  It caused me to lose connection to the Metal
and obviously created more of a problem than I was aware of.  After doing a
factory reset and re-following the client install directions, I then got it
to connect properly.
This wasn't your fault. The sector should never have been configured
to request DHCP from you.
FYI..  Some of the client install directions could use some tweaking as they
may be misleading for some.  The NTP synchronization step should probably be
pushed farther to the end of the directions (after connecting to the
network).  Also, when configuring the local DHCP server, step 2 needs to
define the network address, not the local ethernet address (i.e.
192.168.88.0/24, not 192.168.88.1/24 like it shows).
Fixed.
If you check the history on that wiki page, you'll see quite a few
edits in the last few days. I clarified some things and introduced
some new issues (like the DHCP server network).
Tom
