This is some really broad strokes.  Are there specifics on ID-1 protocol / framing somewhere?
On 5/27/2014 4:59 PM, John D. Hays wrote:
ID-1 simply encapsulates an Ethernet frame behind a D-STAR header.  The header has some correction, but the Ethernet frame is not corrected by D-STAR.
John D. Hays
K7VE
On Tue, May 27, 2014 at 4:28 PM, Bart Kus <me@bartk.us> wrote:
There's no protocol I'm aware of that implements these features on top of ID-1.  You'd need the ability to receive corrupt frames from the ID1 to allow the use of FEC.  How does the ID1 handle corrupt frames?  Is there a CRC or something in the framing?  For ARQ, you could keep the TX retrying until it hears an ACK or times out.  Custom software would be needed, or perhaps pppd can do such tricks, I dunno.
Did you hear any signal when you listened with an FM receiver?  Can you use an RTL-SDR or equivalent to see if there's any signal present?
On 5/24/2014 8:36 PM, Dean Gibson AE7Q wrote:
So, my next question:  Is there an available tunneling protocol that employs those features?
Note that with the ID-1 in the one watt setting (same omni antenna), I can use the 1.2GHz KB7CNN repeater 35 miles away on East Tiger mountain, with no noise in the FM signal. The link to Paine (5 miles away) was tried at max power (ten watts) on both radios.  I tried two different frequencies (that's the beauty of being able to control both radios from one location!): 1.250GHz and 1.249GHz (I listened on both in FM mode), with no significant difference.  So, in my opinion, it's a path problem.
Wow that sucks.  :(  Is the signal level just too low?  Is it a matter of interference?
And yeah, I can confirm that the microwave stuff we use includes both FEC (at up to 1/2 rate) and an ARQ system (look at "hw-retries" setting).  These features are common to all WiFi systems too, and they're just carried over into our NV2 TDMA system.
