OK, everything is back working, and I have my dBm back!!
Not a comedy of errors, but two factors intertwined to create this problem:
  1. Since configuring the radio after a configuration reset requires the use of WinBox (until you get IP addresses set up), I moved the network connection from the radio to its normal router on the DMZ, and connected it to a router on my LAN via an extension Ethernet cable and a "dual-RJ-45-jack adapter".  The port light on the router associated with the radio connection was off.  This morning when I went to disconnect the cables, I saw the port light on the router flash momentarily.  Junked the dual-RJ-45 adapter and used another one (I had previously tried a different cable), and I had WinBox access to the radio!  Everything worked except for the LEDs ...
  2. After much more screwing around, I found out that for version 6.12, the LEDs are not configured by default !!!  Remember, I had done a "reset-configuration" ...
So, for others that update to v6.12, here are the relevant lines in the setup:
/system leds add type=interface-status interface=ether1-local leds=user-led
/system leds add type=wireless-signal-strength interface=wlan1-gateway leds=led1,led2,led3,led4,led5
Now that I know I can configure the LEDs with other options, I'll try some.  On the IBM PC, I wrote a program for the keyboard LEDs called "Motel" ...
I have no clue as to why my dBm dropped, and why I now have my prior values back ...
-----Original Message-----
Well, this did not end well.  ... I decided to reset the configuration (using the command line) ... it appears to have "bricked" the radio.
It draws about 160ma (about the value from a week ago, when I first measured it).  There is no light on the side of the unit, and the Ethernet port is dead.
