As a long time member of that industry myself, I can assure you that's not the case.  Hashing is indeed a cryptographic function.
Just because I use basic terminology in these messages for the sake of the audience, doesn't mean I'm not aware of how it works.  As HamWAN's license trustee, I am quite literally betting my license on it. ;)
On Tue, Mar 16, 2021 at 2:23 PM Stephen Kangas <stephen@kangas.com> wrote:
As is so often happens, a public dictionary definition is not always correct.  It is well understood in the information security industry that I work in, and in military usage, to always mean prevention of unauthorized access/discovery of information.
Hashing, CRC, etc, processes used for insuring information *integrity* are NOT encryption…because they are one-way, ie the intent is not for anyone to decode the information regardless of whether they are “authorized” users or not.  Hash algorithms are typically used for verifying a message/file has not been corrupted in transit or otherwise changed, or for hiding a password (but one that cannot be decoded from the hash, ie there is no recipient key to do that).  This only matters for this HamWAN case in that CRC checksums and any Hash values are communicated in an unencrypted manner, used by system components to insure integrity of data packets and perhaps entire email messages (not sure about that one), so the “encryption” prevention of Part 97 does not apply to that.  Encryption algorithms such as SSL is not used to insure integrity, as even an encrypted message/packet can become corrupted, or changed by a man-in-the-middle attack such that it loses integrity.
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Cory (NQ1E)
Sent: Tuesday, March 16, 2021 1:45 PM
>  “encryption” means purposefully hiding/obfuscating/coding information with intent of unauthorized users to discover/decode the information. [...] encryption by definition is used to keep information private
You're close, but it's more nuanced than that.  The actual dictionary definition of encryption is:
"the process of converting information or data into a code, especially to prevent unauthorized access."
They way most cryptographic protocols prevent "unauthorized access" is by using three major features, and they're not all always required:
1. Privacy - Using a cipher to encode a message in a way that hides its true meaning
2. Authentication - Verifying that the message was sent from the intended party
3. Integrity - Verifying that the message is complete and has not been altered in transit
You may be surprised to hear that the word "encryption" is not actually used anywhere in part 97.  What it actually says is:
"No amateur station shall transmit [...] messages encoded for the purpose of obscuring their meaning, except as otherwise provided herein" - §97.113(4)
There is nothing prohibiting us from using the non-privacy related features of cryptography in regular transmissions.  While not common, disabling ciphers is possible in SSL, SSH, and other internet protocols.  Even the IPSec tunnels HamWAN uses are part97 compliant since you can absolutely see the original traffic encapsulated in the tunnel, even though you cannot alter or impersonate it without the proper keys.
On Tue, Mar 16, 2021 at 12:35 PM Stephen Kangas <stephen@kangas.com> wrote:
Let’s keep in mind that “encryption” means purposefully hiding/obfuscating/coding information with intent of unauthorized users to discover/decode the information.  To accomplish encryption, both a cipher and a key are needed; the cipher is an algorithm-driven means to hiding the information and the key is used to perform the encryption and decryption.  Symmetric encryption uses a single key shared between authorized users, whereas asymmetric encryption typically uses mathematically related key pairs…it is the latter that is done with TLS/SSL via the Public Key Infrastructure.  Regardless of how it is done, encryption by definition is used to keep information private to those who do not know the cipher or have the correct key, which is not legal in Part 97 for any purpose as I read it, whether for authentication, integrity, or confidentiality of communications.
As we hams know, there are methods of “coding” information that may seem like purposeful encryption, but are not because the ciphers and keys are publicly, even widely, available to anyone.  Examples include Morse Code, CRC checksums (for integrity), IPA, digital communications protocols OTA, etc.  These are not encryption (contrary to how some old hams argue who do not understand PSK31 or other “new” digital protocols for example).  So the question pertaining to what we’re discussing is: is the intent to purposely make the data private for some by a few or even a group of only those people (or machines/programs) who know the cipher used and have the key to decode?  Apparently the connection from default installation of Winlink Express for Windows to CMS does intend to keep that traffic private using a method very difficult to break encryption for most public observers (at least when local RMS is performed during the install).
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Aaron Taggert
Sent: Tuesday, March 16, 2021 8:27 AM
On the authentication/integrity side... FCC says no encryption so we can all hear what you're on about. Ham would not be much fun if all you heard was encrypted pseudo noise. SSL/TLS authentication is a bit like me sending you a list of 100 words and asking you to tell me word 45. Everything is in the clear, but I can authenticate that whomever is at the other end at least has the right list. Another SSL/TLS feature is integrity, meaning the whole message is received. They would be like saying I sent 3421 characters CW 786 of them were vowels. Again everybody can hear what we're saying but it would be difficult to impersonate the sender (or receiver) or change the message.
On Tue, Mar 16, 2021, 6:32 AM Steve - WA7PTM <psdr-list@aberle.net> wrote:
telnet mode?
> -Scott
>> Scott, thanks for that update, interesting.  “Telnet” is a misnomer in
>> (whereas SSH is encrypted).   It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>>    Successfully connected to a CMS through port 8772 in 253 Milliseconds
>>    Successfully connected to a CMS through port 8773 in 311 Milliseconds
>>    Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>>    Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>>    Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>>    Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client.  Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN.  As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish.  As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight.  Items in the Fresnel
>> regular internet and HamWAN for a Winlink node.  My suggestion would be to
>> other if the one goes down.  You can also acquire routers that include
>> failover capability to automatically make that switch.  You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status.  I's not linking to anything since the antenna is
>> still on the ground.  How much configuration can I do before mounting it on
>> my roof.  The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal.  My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon.  Making progress...
>> *Phil Cornell  *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES  VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
