His speeds look fine today.[tom@Baldi-S3] > /ip dhcp-server lease print
Flags: X - disabled, R - radius, D - dynamic, B - blocked
# ADDRESS MAC-ADDRESS HOST-NAME SERVER RATE-LIMIT STATUS
0 D 44.24.240.252 64:D1:54:AD:8C:13 W7CLO-Baldi dhcp1 bound
1 D 44.24.240.251 CC:2D:E0:1E:DE:C7 WA7AUB-Baldi dhcp1 bound
[tom@Baldi-S3] > /in wi registration-table print
# INTERFACE RADIO-NAME MAC-ADDRESS AP SIGNAL-STRENGTH TX-RATE UPTIME
0 wlan1-gateway W7CLO/Enumcla... 64:D1:54:AD:8C:13 no -70dBm 29.2... 13h34m40s
1 wlan1-gateway WA7AUB/Auburn... CC:2D:E0:1E:DE:C7 no -73dBm 29.2... 13h34m40s
[tom@Baldi-S3] > /tool bandwidth-test 44.24.240.251 duration=10
status: done testing
duration: 10s
rx-current: 14.8Mbps
rx-10-second-average: 14.0Mbps
rx-total-average: 14.0Mbps
lost-packets: 0
random-data: no
direction: receive
rx-size: 1500
[tom@Baldi-S3] > /tool bandwidth-test 44.24.240.251 duration=10 direction=transmit
duration: 11s
tx-current: 14.2Mbps
tx-10-second-average: 12.8Mbps
tx-total-average: 12.8Mbps
random-data: no
direction: transmit
tx-size: 1500
On Sat, Nov 2, 2019 at 8:31 AM Bart Kus <me@bartk.us> wrote:If it's a pre-wired unit like the DynaDish 5, you can't change polarities. Will just need to live with the confusion._______________________________________________
That is pretty bad upload performance. It could use some spectral analysis on the HamWAN side, and perhaps testing with another client on the same sector to find the cause. I hope it wasn't caused by the 10MHz bandwidth change!
I don't have time to address this right now, so hopefully someone else can step in.
The download numbers look fine though.
On 11/1/2019 8:22 PM, Scott Currie wrote:
So, it's not clear to me how to change the polarity on the channels. I'll do some reading. It's a DynaDish 5.
These numbers look low, I may not be doing this right:
/tool bandwidth-test 44.24.240.197 duration=30s direction=transmit
status: running
duration: 29s
tx-current: 11.9kbps
tx-10-second-average: 11.9kbps
tx-total-average: 25.7kbps
random-data: no
direction: transmit
tx-size: 1500
connection-count: 20
local-cpu-load: 4%
/tool bandwidth-test 44.24.240.197 duration=30s direction=receive
status: running
duration: 29s
rx-current: 12.8Mbps
rx-10-second-average: 12.2Mbps
rx-total-average: 12.0Mbps
lost-packets: 1192
random-data: no
direction: receive
rx-size: 1500
local-cpu-load: 16%
-Scott
On Fri, Nov 1, 2019 at 8:06 PM Bart Kus <me@bartk.us> wrote:
It appears you're connected to the Baldi site. That's probably the only site remaining that still doesn't have MIMO (2-chainz) modems. It only provides service with horizontally polarized signals.
It looks like your modem's setup to receive HPol on ch1. HamWAN typically suggests HPol be wired to ch0, and all our network gear follows that standard:
http://hamwan.org/Standards/Component%20Engineering/Client%20Hardware.html
It makes troubleshooting easier when there's a clear polarity-to-chain mapping.
I'm also not sure why we're still running that sector at 5MHz bandwidth, it should be 10MHz. I've gone ahead and updated the sector's config to be 10MHz. This should provide you with a bit more speed, at the cost of 3dB of signal power, which you can afford given your -66dBm link.
Feel free to run some bandwidth-tests to Baldi-S3.hamwan.net (44.24.240.197) to confirm performance.
PS: The "tx-signal-strength-ch0" is reported back to you from Baldi-S3 (how well it hears you), since Baldi-S3 only has a ch0, even though that's not your tx-ch0, but rather your tx-ch1 that it's measuring. You see how confusing things get when polarities are flipped? :)
On 11/1/2019 7:46 PM, Scott Currie wrote:
So, should I be concerned about my ch0 numbers?
-Scott
[ns7c@WA7AUB-Baldi] > /interface wireless monitor 0--
status: connected-to-ess
channel: 5880/5/an
wireless-protocol: nv2
tx-rate: 6.5Mbps-5MHz/1S
rx-rate: 13Mbps-5MHz/1S
bssid: D4:CA:6D:7A:A3:EF
radio-name: N7FSP/Baldi-S3
signal-strength: -66dBm
signal-strength-ch0: -90dBm
signal-strength-ch1: -66dBm
tx-signal-strength: -67dBm
noise-floor: -101dBm
signal-to-noise: 35dB
tx-ccq: 47%
rx-ccq: 79%
authenticated-clients: 1
current-distance: 31
wds-link: no
bridge: no
routeros-version: 6.41.3
Sent from my mobile device...
-Scott
