SSL (more properly SSL/TLS) is an umbrella term. There are many ciphers and protocol versions that the client and server negotiate. To comply with the FCC requirements of no encryption you would use a NULL Cipher, meaning no encryption. Because nearly nothing supports this you'd need an SSL/TLS proxy with compatible certificates installed on the clients.
See attached for winlink specific analysis of 'SSL'.
From Stack overflow: "Yes, TLS and SSL support "no-encryption" modes. Whether the particular client and server in question are configured to enable is a separate issue.
It's possible, though unlikely, that a server could enable one of these cipher suites by default. What is more likely is that a server would enable weak cipher suites (like the "export"-grade DES-based suites) by default. That's why you should carefully review the server's whitelist of cipher suites, and leave only a few trusted, widely-supported algorithms.
You can use the TLS_RSA_WITH_NULL_SHA cipher suite, among others, to protect the authenticity and integrity of traffic, without encryption.
The "RSA" in this case refers to the key exchange algorithm, while "SHA" refers to the message authentication algorithm used to protect the traffic from being altered. "NULL" is the encryption algorithm, or, in this case, the lack of encryption.
It's important to realize that the traffic, though it's not encrypted, is bundled up in SSL records. The client and server must be SSL-enabled.
If you are looking for a step-down solution where some data is exchanged over SSL, then SSL is turned off but the application traffic continues, that's possible too, but keep in mind that it offers absolutely no security for the cleartext traffic; it can be tampered with by an attacker. So, for example, authenticating with SSL, then stepping down to an "in-the-clear" protocol to receive commands that use the authentication negotiated via SSL would unsafe."
And if you're really bored check out this SSL/TLS analysis: http://blog.fourthbit.com/2014/12/23/traffic-analysis-of-an-ssl-slash-tls-session/
On Tue, Mar 16, 2021, 7:58 AM Scott Currie <scott.d.currie@gmail.com> wrote:
Here is my, probably incomplete, understanding of things. Originally, connections to the CMS from either clients (Winlink Express) or gateways (RMS Packet, RMS Trimode) were on port 8772 using telnet. About a year ago they introduced port 8773 which uses SSL. For the WDT products, this is now the preferred port and is tried first. If the connection fails, they will try port 8772, and today this will still work. At some point port 8772 will be turned off. Non-WDT clients and servers (BPQ, Pat, Outpost) can still use port 8772 today, but will need to switch to port 8773 eventually. I do not know what the traffic looks like on port 8773. They say it is still telnet, so I don't know if they are using SSL for authentication, and then switching to plain text, or if they are establishing an encrypted tunnel and then sending telnet through the tunnel. I'll have to trace it and see what is going on.
Client and gateway connections to RMS Relay go over port 8772 using telnet, and this will not change. P2P telnet connections will continue to be unencrypted (the port default is 8772 but can be changed). RMS Relay connections to the CMS will be over port 8773 SSL.
I'm not smart enough to interpret FCC rules to know if encrypted authentication is OK, as long as the actual traffic is plain text.
-Scott, NS7C
On Tue, Mar 16, 2021 at 6:32 AM Steve - WA7PTM <psdr-list@aberle.net> wrote:
telnet mode?
> -Scott
>> Scott, thanks for that update, interesting.  “Telnet” is a misnomer in
>> (whereas SSH is encrypted).   It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>>    Successfully connected to a CMS through port 8772 in 253 Milliseconds
>>    Successfully connected to a CMS through port 8773 in 311 Milliseconds
>>    Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>>    Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>>    Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>>    Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client.  Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN.  As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish.  As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight.  Items in the Fresnel
>> regular internet and HamWAN for a Winlink node.  My suggestion would be to
>> other if the one goes down.  You can also acquire routers that include
>> failover capability to automatically make that switch.  You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status.  I's not linking to anything since the antenna is
>> still on the ground.  How much configuration can I do before mounting it on
>> my roof.  The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal.  My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon.  Making progress...
>> *Phil Cornell  *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES  VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
-Scott
