Hi Doug,
We have used the DynaDish 5 successfully to link a couple of sites to Triangle mountain (item number 4 in Bart's list). As mentioned, you do need to ensure you get the newer hardware version to support 5/10MHz channels (exact model we have in use is RouterBOARD DynaDish G-5HacD r3)
Chris
We (HamWAN) maintain an up-to-date table of client hardware options:
http://hamwan.org/Standards/Component%20Engineering/Client%20Hardware.html
It's not an exhaustive list, just top recommendations along with notes / rationale.
On 4/30/2019 12:29 PM, Todd Lilleness wrote:
On Tue, Apr 30, 2019, 12:24 PM Steve - WA7PTM <psdr-list@aberle.net> wrote:
Slides 37-39 in this presentation might help:
https://www.mil.wa.gov/uploads/pdf/weccwg/scott_burrows_weccwg_2019.2.7_presentation.pdf
Doug Collinge wrote on 4/30/19 11:30 AM:
> I want to join HamWAN so I checked into the recommended hardware, the
> MikroTik RBMetal5SHPn. It is no longer available from my supplier and seems
> to have been discontinued by the manufacturer. My supplier recommended the
> MikroTik RBMetalG-52SHPacn as a replacement.
> The RBMetal5SHPn seems to be very well suited to the application. Should I
> make an effort to find remaindered stock?
> The RBMetalG-52SHPacn is slightly more expensive but would also be good, if
> it works. I have heard rumours... Should I expect this unit to work?
> Does anyone out there have experience with it?
> MikroTik also has a line of "Groove" weatherproof routers. Is any one of
> these suitable? Lower cost but also lower transmit power.
> I'm in Victoria, if that is somehow relevant. No issues with getting the
> "international" versions, anyway!
