Hi Caleb!
The list must be feeling under the weather if I'm the first person to reply to you.  :P  There's been a lot more chatter recently on freenode/#HamWAN.  Feel free to come in and idle if nothing else.
So we had the Tuesday meeting (you should dial in if you can, details on front page of hamwan.org) and gave some thought to what might be up your alley.  One of the things we're trying to do is to improve our lab capabilities in terms of antenna radiation measurement.  Right now we can take 1-dimensional slices of these patterns and produce results like this:
./temp/cache/6daf471697293d9e55e0b9a31e79da09_1.png
You can tell from the above that this particular antenna is fairly well behaved, nice even power spread over a 120 degree front beamwidth, and reasonable sidelobes towards the rear.
But 1D scans don't tell the whole story.  So we bought some hardware to control antenna movement in 2 rotational dimensions.  When this hardware is guided properly, along with the signal measurement equipment, we could generate full blown 3D radiation pattern images like this:
http://www.antenna-theory.com/antennas/reflectors/dish3.jpg
You can see so much more detail here, since it shows exactly what happens at all possible radiation angles in our 3D universe.  One more dimension could be added to this though, and that is frequency.  It would be good to see how these 3D patterns change shape as the antennas are swept through their operational frequency range.  We could also look at characterizing polarization as yet another dimension.
So, long story short, the guy who's been tinkering with getting all the control software written for running these measurements has been swamped for time.  Perhaps with your CS background you wouldn't find it too difficult to help bring this measurement setup into reality?  Here's what's needed:
1) 2-axis control commands need to be sent over a serial port.  Timing and synchronization and reproducibility are considerations here, so it's not entirely arbitrary how this is done.
2) Commands need to be sent to possibly multiple microwave instruments over a GPIB interface.  At the very least, commands to read signal strength.  Better yet though would be commands to setup all the right signal generator + spectrum analyzer parameters and control frequency / etc over the course of the measurements.
3) Once the data is there in RAM, it needs to be made presentable somehow on the web.  WebGL is sounding like a good option for rendering these 3D images in browsers.  People should be able to move the shape around and zoom in/out on it.  There should also be sliders to control any other dimensions, like frequency, or polarity angle.  Right now, I'm not aware of any widget that can present such data on the web.  It would also be good for the data to stay in its raw form on the back-end so that it can be computed on easily in future (unpredictable) ways.  The first radiation pattern I showed you is rendered in real-time by the web server from a couple arrays pasted into the wiki page.  A similar approach in 3D land would be good.
Does any of this sound interesting?  Between Rob Salsgiver and myself, we can provide all the necessary hardware.  It's the software we're missing.  You can see my current 1D software on the Antenna Analysis page, attached at the bottom.
Let me know if this or something else would be up your alley,
On 4/27/2013 10:16 PM, Caleb Skurdal wrote:
Hi all,
I'm Caleb Skurdal AD7U. I met Bart today at the Northwest Linux fest in Bellingham. I've been a ham for about 17 years; though I've been tinkering with electronics for over 22. I have a Computer Science background and all levels of the network stack I find highly interesting. This an exciting project from the purely technical standpoint and I see it as very valuable to the community from a emergency preparedness perspective. I'm excited to learn more about the project and hopefully to be able to contribute to successfully implementing and growing it.
Regards,
Caleb Skurdal
