I would like to use SNMP to facilitate aiming a Node. In order to work on this project, I have setup a Node (LHG XL HP5) and Sector (5SHPn) for testing purposes.
The following shows the status of my Node:
[herbw@AA7HW-01] > /snmp print
enabled: yes
engine-id:
trap-target:
trap-community: hamwan
trap-version: 1
trap-generators: temp-exception
[herbw@AA7HW-01] > /interface wireless print oid
0 tx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.2.1
rx-rate=.1.3.6.1.4.1.14988.1.1.1.1.1.3.1
strength=.1.3.6.1.4.1.14988.1.1.1.1.1.4.1
ssid=.1.3.6.1.4.1.14988.1.1.1.1.1.5.1
bssid=.1.3.6.1.4.1.14988.1.1.1.1.1.6.1
frequency=.1.3.6.1.4.1.14988.1.1.1.1.1.7.1
band=.1.3.6.1.4.1.14988.1.1.1.1.1.8.1
auth-client-count=.1.3.6.1.4.1.14988.1.1.1.3.1.11.1
[herbw@AA7HW-01] > /interface wireless scan 0
ADDRESS SSID CHANNEL SIG NF SNR RADIO-NAME ROUTEROS-VERSION
A RT B 4C:5E:0C:89:3F:57 HamWAN 5880/5/an -28 -124 96 K7ICY-Tolliver
-- [Q quit|D dump|C-z pause]
Based upon the above, I would assume that if I query the signal strength (.1.3.6.1.4.1.14988.1.1.1.1.1.4.1) using snmpget, I would obtain a value of approximately -28 (the signal strength varies a bit from the instantaneous value of -28 reported above). However, although I am able to obtain the SSID using snmpget, I am unable to obtain the signal strength, frequency or band:
$ snmpget -c hamwan 192.168.88.1 .1.3.6.1.4.1.14988.1.1.1.1.1.4.1
SNMPv2-SMI::enterprises.14988.1.1.1.1.1.4.1 = INTEGER: 1
$ $ snmpget -c hamwan 192.168.88.1 .1.3.6.1.4.1.14988.1.1.1.1.1.5.1
SNMPv2-SMI::enterprises.14988.1.1.1.1.1.5.1 = STRING: "HamWAN"
$ snmpget -c hamwan 192.168.88.1 .1.3.6.1.4.1.14988.1.1.1.1.1.7.1
SNMPv2-SMI::enterprises.14988.1.1.1.1.1.7.1 = INTEGER: 0
$ snmpget -c hamwan 192.168.88.1 .1.3.6.1.4.1.14988.1.1.1.1.1.8.1
SNMPv2-SMI::enterprises.14988.1.1.1.1.1.8.1 = ""
Also, is it possible to obtain the Noise Floor (NF), Signal to Noise Ratio (SNR), or Radio Name from my Node using SNMP? These are all reported by the /interface wireless scan 0.
Thanks for any assistance you can provide.
Herb, AA7HW
