The doc I gave Scott was a set of instructions we made for Seattle ACS Members to set up their SNOM 821 IP Phones. Some of that material does not apply widely.
ie: In addition to a HamWAN extension number, Seattle ACS adds a second line appearance on our IP Phones for a separate SIP service using a server in Denver, CO.
We have extension numbers aligned - for example my phone is 8099 on HamWAN, and 1099 on Seattle ACS.
I suggest Municipal EmComm groups request a reasonable number of extension numbers in a sequence/block from HamWAN.
A small town might want 5 extension numbers. A larger city might want 25.
There are soft-phone SIP clients for Android/iPhones, so in a pinch, if you have the extension numbers and passwords pre-arranged, you can quickly add soft phone clients to the HamWAN phone system even if you don't have hardware IP phones available.
There are a wide number of IP Phone choices.
We've been having good success with SNOM 821 refurbished from from Amazon. $29.99
https://www.amazon.com/dp/B0716QGP9R/
On Tue, Apr 23, 2019 at 6:09 PM Rob Salsgiver <rob@nr3o.com> wrote:
Scott,
I have an old set of setup docs I’m going to verify on a couple of phones in the next day or so and will send you an updated copy.
From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Scott Currie
Sent: Tuesday, April 23, 2019 3:18 PM
Subject: Re: [HamWAN PSDR] IP Phones
Hi Rob,
Randy has not given me anything for the phones, so I will go with these for now. Looking at the instructions, it looks like there are several passwords needed that are "to be assigned by your COMT". Can you provide those?
-Scott
On Tue, Apr 23, 2019 at 3:09 PM Rob Salsgiver <rob@nr3o.com> wrote:
Scott,
I have you setup for now with the following extensions:
EOC 1 – 8910
EOC2 – 8911
iPhone – 8912
If you don’t already have setup instructions Randy or I can get them to you.  I didn’t realize you were with Auburn when I jumped in there, and I know Randy’s been working with a number of you folks down there on getting other aspects setup.  He may have a different extension numbering scheme in mind for King County so these may change but they’re enough to get started (with the setup instructions).
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Scott Currie
Sent: Monday, April 22, 2019 10:18 PM
Hi Rob,
Thanks! For now, just two for the EOC, and one for my iPhone.
-Scott, NS7C
On Mon, Apr 22, 2019 at 21:00 Rob Salsgiver <rob@nr3o.com> wrote:
I can setup numbers as well.  Let me know how many you want and we can get them setup.
From: PSDR [mailto:psdr-bounces@hamwan.org] On Behalf Of Doug Kingston
Sent: Monday, April 22, 2019 6:04 PM
Randy has been doing the registration for Seattle ACS, but you may want a block of numbers for your community.  I think Nigel or Tom could help out there.
Shared the ACS configuration instructions for the SNOM 821 with Scott in a separate email.
-Doug-
On Mon, Apr 22, 2019 at 5:47 PM Scott Currie <scott.d.currie@gmail.com> wrote:
Hello World....
I'm working on getting the Auburn EOC up on HamWAN. I have a DynaDish in a portable configuration running, which will become more permanent in the next few weeks. Loads of fun sticking a dish out the side door of the EOC and getting 3 bars off Baldi!
Next questions, how does one go about setting up an IP phone and getting a number? Also, I have a SIP application on my iPhone (Bria) and so I am wondering if I can get a number for it as well.
Can someone enlighten me?
-Scott, NS7C
Sent from my mobile device...
-Scott
