Thanks Nigel. I can nose around about Cougar. Do you know what the issue(s) is(are)? There are several ham repeaters there of course.
As for locations. These are the fire station addresses and GPS coordinates that one of our other members put together:
Station Address City Zip Lat/Long
11 - HQ 8450 161ST AVE NE REDMOND 98052-3848 47.677913, -122.124938
12 4211 148TH AVE NE BELLEVUE 98007-3119 47.648426, -122.143646
13 8701 208TH AVE NE REDMOND 98053 47.680206, -122.063499
14 5021 264TH AVE NE REDMOND 98053-2718 47.651962, -121.987793
16 6502 185TH AVE NE REDMOND 98052-5039 47.664105, -122.093651
17 16917 NE 116TH ST REDMOND 98052-2246 47.703403, -122.114135
18 22710 NE ALDERCREST DR REDMOND 98053-5845 47.692245, -122.03717
My thinking is to have a "core network" of links between stations 12, 13, and 17. Of all the stations, 13 seemed to be the most promising. Station 12 is practically next door to Microsoft's main campus and the noise level is huge there, but it potentially has great shots to several other stations which makes it attractive to having in the core. Station 17 has become somewhat of a "hub" station for ARES -- at least we continue moving in that direction; trees could be an issue there. One or two of the other stations might have coverage potential, but it's all showing even more spotty on the map than these others. (Of course if we were able to access a node on Cougar, everything changes for the better...)
In terms of height, there are a number of factors that may limit us, BUT the fire stations have "hose towers" (for hanging hoses to dry after use) which are pretty tall. I think 20 - 30 feet might be doable. The lower the better from a "political" point of view, the higher the better from a "technical" point of view. ;-)
Any thoughts would be appreciated.
(I have been using the
ubnt.com/airlink site for doing some of this analysis as well as some other tools. A recent test we did seemed to confirm its validity although it was a bit optimistic -- that is, leaning more towards the "theoretical" which isn't surprising.)
