Steve,
Your client radio (DynaDish5) should have two DHCP
configurations. DHCP Client and DHCP Server.
Your wlan interface should be configured as a
“station”, and in that mode you attach the DHCP Client to the
WLAN interface.
There should be no bridge on a DynaDish.
There’s nothing to bridge as you will be routing
between the Wlan interface and the Ethernet interface, along
with network address translation.
The client configurations on the website are
generally correct for most installations.
There are some steps that would be better if in a
different order, but not too far off.
Thanks to
Doug, we determined that dhcp on this unit needs to point to
the "bridge" as opposed to the "wlan1" interface. That
change got the
DynaDish connected last night, but there are still some DNS
issues to be
resolved before it is fully functional.
Hopefully, we will end up with an improved set of
step-by-step instructions.
Doug Kingston wrote on 2/13/19 12:08 PM:
> I can take care of these updates. I'll work with
Steve.
> -Doug-
> On Wed, Feb 13, 2019 at 12:00 PM Steve - WA7PTM <psdr-list@aberle.net>
> wrote:
>> Is anyone maintaining the
>> https://www.hamwan.org/Standards/Network%20Engineering/Client%20Node%20Configuration.html
>> web page?
>> The reasons I ask are:
>> • Step 1 will not work as listed as the command is
wrong (should be
>> "/system package update install" in RouterOS
v6.43.12) and if some
>> preliminary steps are not taken (moving the default
network to one
>> connected to the Internet with a "/ip address add
address=a.b.c.d/xx
>> interface=ether1" command and establishing a
default gateway with a "/ip
>> route add gateway a.b.c.gw"
command), then the update will fail.
>> • Step 21 on a Dynadish5 results in a "failure:
incompatible band and
>> channel-width" message unless "channel-width=5mhz"
is added to the command.
>> • Step 22 on a Dynadish5 results in a "failure: can
not run on slave
>> interface" message.
>> This last one has me stumped, and I have been
unable to determine a
>> workaround. Has anyone else encountered and solved
this problem?
>> Thanks,
>> Steve
>> PSDR mailing list
>> PSDR@hamwan.org
Sent from mobile.
