Nope -- although I have an IP coming from Gold Mountain (apparently), my internet was coming from my local connection.  If I plug straight into the model over ethernet from my computer (instead of having the ethernet connected to my home internet router), I'm still not able to hit the net.
On Fri, Jun 2, 2017 at 10:36 PM, Dave Stewart <dstewartgo@gmail.com> wrote:
I think I may have figured it out (but unfortunately by virtue of poking around without taking notes).  I used the web config interface to the modem and told it to grab an IP off the wlan interface, and it got an IP of  44.24.240.104, which looks right.
On Fri, Jun 2, 2017 at 10:11 PM, Dave Stewart <dstewartgo@gmail.com> wrote:
Hello -- I'm trying to set up a connection, using the instructions here:
I'm getting all the way to the point where I try to do a tracert ("Connect" step 3), but nothing is coming through.
My monitor shows the following -- any ideas what I should do next?  Am I just not hitting the Gold Mountain node well enough?
[admin@K7XST-Gold] > /interface wireless monitor 0
                  status: connected-to-ess
                 channel: 5900/5/an
       wireless-protocol: nv2
                 tx-rate: 14.4Mbps-5MHz/2S/SGI
                 rx-rate: 1.6Mbps-5MHz/1S
                   bssid: E4:8D:8C:F1:6D:22
              radio-name: Gold-S2/K7WAN
         signal-strength: -76dBm
     signal-strength-ch0: -78dBm
     signal-strength-ch1: -80dBm
      tx-signal-strength: -71dBm
  tx-signal-strength-ch0: -73dBm
             noise-floor: -107dBm
         signal-to-noise: 31dB
                  tx-ccq: 54%
                  rx-ccq: 6%
   authenticated-clients: 1
        current-distance: 33
                wds-link: no
                  bridge: no
        routeros-version: 6.36
                 last-ip: 44.24.240.97
     notify-external-fdb: no
