Mark,
I have found that running this command instead works to resolve the issue
/interface wireless
set 0 disabled=no frequency-mode=superchannel band=5ghz-onlyn mode=station scan-list="HamWAN" ssid=HamWAN wireless-protocol=nv2
Note the quotes around the scan-list value. Alternatively setting the scan-list value in winbox usually works.
On Wed, Jan 24, 2018 at 11:50 AM, Mark Tellez <mark.tellez@gmail.com> wrote:
I am trying to get a Hamwan node setup and I have run into an issue that I can't seem to solve.
I have followed the directions step by step but when I get to the final stage and go to connect I get a problem with there being no frequencies in the scanlist.
I have heard this may be a know bug.   I was hoping that someone might be able to provide a documented work around.
Mark
On Sun, Jan 7, 2018 at 10:07 PM, Mark Tellez <mark.tellez@gmail.com> wrote:
I am wanting to get some advice on the equipment I need to get onto Hamwan.  I have read the information on the website and attended a presentation back in the fall to the Seattle ACS group. It was my understanding that some of the suggestions on the list were no longer current or available.  I am considering the LHG 5 antenna but the cost on the website is about 3 times the cost noted on the HamWan site so....Suggestions? Thoughts?
Mark
[NOTE:  This E-Mail message is for the sole use of the intended recipient(s) and may contain FOUO, confidential and privileged information. Any unauthorized review, use, disclosure or distribution is PROHIBITED. If you are not the intended recipient, please contact the sender by reply e-mail and DESTROY all copies of the original message.]
_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/_/
Mark Tellez
