On the authentication/integrity side... FCC says no encryption so we can all hear what you're on about. Ham would not be much fun if all you heard was encrypted pseudo noise. SSL/TLS authentication is a bit like me sending you a list of 100 words and asking you to tell me word 45. Everything is in the clear, but I can authenticate that whomever is at the other end at least has the right list. Another SSL/TLS feature is integrity, meaning the whole message is received. They would be like saying I sent 3421 characters CW 786 of them were vowels. Again everybody can hear what we're saying but it would be difficult to impersonate the sender (or receiver) or change the message.
telnet mode?
> -Scott
>> Scott, thanks for that update, interesting. “Telnet” is a misnomer in
>> (whereas SSH is encrypted). It looks like the email client is connecting
>> internet.
>> --Stephen W9SK
>> Winlink Express Link Test:
>> Successfully connected to a CMS through port 8772 in 253 Milliseconds
>> Successfully connected to a CMS through port 8773 in 311 Milliseconds
>> Successfully performed API service to api.winlink.org through port 443
>> in 756 Milliseconds
>> autoupdate2.winlink.org...
>> Successfully checked autoupdate server through port 443 in 439
>> Milliseconds
>> Successfully connected to www.winlink.org through port 443 in 47
>> Milliseconds
>> Successfully connected to ftp://ftp.swpc.noaa.gov/pub/latest/SGAS.txt
>> -Scott, NS7C
>> hoster & client. Winlink does NOT use encryption, thus is legal, and is
>> the primary application for my ARES team using HamWAN. As Kenny points
>> FWIW, Stephen W9SK
>> Good luck,
>> Kenny, KU7M
>> Hi Phil,
>> dish. As to “just over them”, a microwave shot consists of the direct,
>> cigar shaped “balloon” around the pure line of sight. Items in the Fresnel
>> regular internet and HamWAN for a Winlink node. My suggestion would be to
>> other if the one goes down. You can also acquire routers that include
>> failover capability to automatically make that switch. You can go more
>> Carl, N7KUW
>> PSDR
>> *To:* psdr@hamwan.org
>> and reporting status. I's not linking to anything since the antenna is
>> still on the ground. How much configuration can I do before mounting it on
>> my roof. The only question in my sight path may be some trees but I think
>> I can aim just over them and get a signal. My friend Bruce/WA7BAM will be
>> helping with the antenna installation on Wed afternoon. Making progress...
>> *Phil Cornell *
>> *W7PLC *
>> *SHARES NCS590*
>> *Hybrid Gateway W7PLC*
>> *TCARES VP*
>> PSDR mailing list
>> PSDR@hamwan.org
>> PSDR mailing list
>> PSDR@hamwan.org
>> *-Scott*
>> PSDR mailing list
>> PSDR@hamwan.org
