Nigel,
The TC-Pro looks like it’s outdoor rated, but not so much tower use. In some cases that I may go, I will be collocated with public safety equipment and I know that the cable they will require must be tower rated cable. I like this stuff, even at it’s price, since it can be grounded just like coax at the required points of contact using standard grounding kits provided by Times or Belden. I get it’s pricy, but I’d rather be safe than sorry.
Jamie Hughes
WA7JH
Mobile: (360) 340-8886
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Nigel Vander Houwen
Sent: Sunday, September 1, 2019 8:55 PM
Subject: Re: [HamWAN PSDR] 1/2" Outdoor UV Protected CAT 5e
Ooof, that pricing is real rough. Unless there’s a real specific circumstance, it’s pretty hard to justify a 50x+ cost increase for some ethernet cable.
On Sep 1, 2019, at 20:18, Jamie Hughes <wa7jh@outlook.com> wrote:
All,
Please see attached data sheet. And I got an email with pricing:
Custom cuts are $10/ft but I can do a full 1000ft spool for $7500
Jamie Hughes
WA7JH
From: PSDR <psdr-bounces@hamwan.org> On Behalf Of Tim Osburn
Sent: Sunday, September 1, 2019 8:01 PM
Jamie,
                You happen to know the cost per foot on that.
All,
I’m not sure what the current cable type and product is running from tower mounted antennas to the equipment in the site shelters, but check this product out. I came across this Outdoor rated CAT5e cable designed to mount alongside coax on a tower. It grounds like ½” coax. This is exciting things that jumped out to me:
  1. Mounts to towers using common coax rubber doughnut ½” mounts
  2. Can be grounded just like coax to meet the requirements of the site owner
  3. Is Outdoor rated
  4. Is UV rated
If interested, please see Tyler Booth, contact card attached.
Jamie Hughes
WA7JH
<20190901_164356.jpg><Tyler Booth.vcf>_______________________________________________
<NWT-CAT5E-ST-O-S-A-001 Datasheeet.pdf>_______________________________________________
